Print Storage - Safety?
Discussion in 'Film Discussion and Q & A' started by Archivist, Jun 22, 2009.
  1. Archivist
    Archivist TPF Noob!
    Jun 22, 2009
    I purchased PrintFile brand archival sleeves for a number of antique photos, which need to be stored for the long term.
    They are supposed to hold 4 prints per sleeve, but the only way to do that is to insert the prints touching back to back-- I called the company to confirm this.
    They assure me it's safe, but I worry about having two photographs touching back to back for long storage. Can anyone share experience or advice? Thank you in advance!
  2. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    As long as they are kept relatively dry (read: very low to no humidity) then there should be no problem as you will not have two sirfaces of emulsion sticking together for long periods.
  3. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    Absolutely do not do that for long term archival storage, they will and can stick together. If these negatives are truly valuable to you forget the plastic stuff and get buffered paper sleeves or envelopes to store your negatives and then put those in a buffered archival box, then store them in cool, low humidity area of your home.
  4. Archivist
    Archivist TPF Noob!
    Jun 22, 2009
    Thank you both so very much.
    Christopher- I received a similar reply when I contacted a photo preservation company. I will make sure the photos are stored somewhere clean and dry.
    JC- They are prints, not negatives. Thank you anyway, though. If you have an opinion about prints, I'd be interested to hear it.
  5. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    print files are cheap. i won't store then back to back.
    just my 02 cents
  6. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    Buffered tissue between the prints stored in an archival box.
    If they are to be mounted, ArtCare brand mount board is the best available, not only is it an acid free board, but actively protects against environmental pollutants, no other board that I am aware of has this level of protection.
  7. ann
    May 14, 2007
    4,263
    189
    the above system mentioned by jc is what i do, when you have important prints, and i mean those that are important to you; as these seem to be, go the best route.
