Printing large from a jpg
Discussion in 'Digital Discussion & Q&A' started by liquidmetaljesus, Aug 6, 2006.
  1. liquidmetaljesus
    liquidmetaljesus TPF Noob!
    Aug 6, 2006
    I just had a hard drive crash,erasing all my .psd files. I'm lookin to get a large format printer, something in the 13x19 range. Would printing from a jpg yield noticibly worse results than from a much high resolution .psd/.tif? Thanks.
  2. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Depends. What resolution were these and what compression did you use on the jpgs? More compression equals less quality
  3. liquidmetaljesus
    Aug 6, 2006
    the .jpg resolution is typically between 11-1300x700x1000 in jpg format, where as the .psd resolution is 3-4,000x2-3000. I would typically resize the photo in photoshop to about 30% or so, then save as, save as a jpg, and the options I used are image quality 8-9, with the ticker about 75% up on the small file/large file line, Baseling (standard) selected and at 56.6kbps, if any of that makes sense
  4. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    The quality will probably be to low, just because 13x19 is quite big. You could always just try really high quality interpolation.
  5. liquidmetaljesus
    Aug 6, 2006
    Would 11x14 be okay for those resolutions of jpgs?
    And would the higher resolutions be okay for 13x19 anyway, really? None of my equipment can scan higher than that,, so itd be pointless to spend too much money on something I cant use.
  6. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Also the typical viewing distance of the picture to displayed is a major factor as well. There was a large print on display at a camera store several years ago when digital was relatively new. It was displayed high above eye level over a display case. The digital print looked beautiful up there. Up close... it didn't looks so nice but the print was large enough that the proper viewing distance was pretty far anyways.
