Prints partially underexposed
aprillove20
Australia
Hello... I have a Meopta opemus 6 enlarger with an El-Nikkor 50mm f2.8. The problem is that in all my photos, the right side is quite underexposed, not only the photo, but the film frame too. I can't figure out what's the cause?
Were you using flash?
If so, you may have exceeded the max sync speed of the camera. That will typically cause a portion of the frame to be underexposed (or completely dark).
Need more info. What camera? Can you post a scan of a negative?
