Probably a really dumb question but can someone
Discussion in 'Beyond the Basics' started by railman44, Jun 22, 2005.
  1. railman44
    railman44 TPF Noob!
    Aug 23, 2004
    580
    Lincoln, NE
    explain what "rubbing" means on a lens? I'm assuming it refers to a slight scratch on the barrel and someone "rubbed" or buffed it out? If I'm correct in this assumption it's fairly easy to spot...
  2. spiralout
    spiralout TPF Noob!
    Nov 11, 2004
    679
    4
    University of Houston
    Hmm... could you give us the context?
  3. railman44
    railman44 TPF Noob!
    Aug 23, 2004
    580
    Lincoln, NE
    Check out eBay. Quotes like "some light rubbing". This can refer to camera or lens. Heck, I thought I was the only one who didn't know what it meant...
  4. spiralout
    spiralout TPF Noob!
    Nov 11, 2004
    679
    4
    I would hope it would stipulate whether it refers to the body or to the lens! I wouldn't trust an item that had "light rubbing" on the lens. I'm sure it only means that there is some wear on the lens barrel, though. Make sure to email them if you aren't sure.
  5. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    Yeah, from what I've seen, "rubbing" refers to the wearing out of the lens barrel resulting in loss of the black layer... etc...
  6. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Sounds like they mean a spot where the finish has been worn down.
  7. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    I was under the impression it was the same as brassing - so yeah, something which cosmetically affects the hardware and subsequently the value, but not the picture-taking.
    It's the kind of subjective term I don't like - my mind says to me: rubbing = battered
    Rob
  8. Hertz van Rental
    Hertz van Rental TPF Noob!
    Nov 8, 2004
    16,728
    45
    Where am I now?
    Battered means it has dents - usually through being dropped.
    Rubbing refers to patches of the body finish that have been rubbed away or abraded. You get it a lot around the neck strap mounts, for example, where carrying the camera around has caused the strap and/or mounting ring to rub against the body affecting the finish.
    It doesn't necessarily mean the camera has been abused or heavily used - just carried around a lot.
    It's a bit like first editions of books. 'Foxing' means that the pages have little brown spots on them - usually from iron salts. The book is fine and perfectly readable but because it is cosmetic it reduces the price considerably. Means you can often pick up a bargain.
