problem: shutter fires when winding
Discussion in 'Photography Equipment & Products' started by panocho, May 1, 2007.
  1. panocho
    panocho TPF Noob!
    Feb 7, 2005
    425
    Compostela, GZ
    My Nikon FM (which I hardly use, but have as an occasional backup) has recently developed an issue: after releasing the shutter, when I wind it automatically shoots the shutter again. Obviously I have to wind again, and sometimes it even shoots for a second time. The result is that most of the times I get two exposures when I just wanted one (the second one being completely useless, of course, since I am normally pointing the camera nowhere), or even three. Sometimes, though, it just works fine.
    Any idea of what could be wrong here and how to (easily) fix it?
  2. Mike_E
    Jan 26, 2007
    5,327
    266
    Sounds as though you have grit (or something) between the shutter button and the housing around it. Start with a can of 'caned' air. I don't know about introducing chemicals into the thing but after asking around and not being directed otherwise put a few drops of lighter fluid there and then blowing it out with the canned air if the air alone didn't work. Followed by 1 maybe 2 drops if a very light machine oil applied with a sowing needle. (dip the needle into the oil and apply the single drop that will stay on the point of it).
    Better yet, send it in for a TLC. ;)
    mike
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Why not just remove the motor drive and cycle it by hand?
  4. panocho
    panocho TPF Noob!
    Feb 7, 2005
    425
    Compostela, GZ
    :shock: Sorry if I was not clear enough with my explanation, but I have no motor drive in the FM and always cycle it by hand. That's precisely where the problem is.
  5. panocho
    panocho TPF Noob!
    Feb 7, 2005
    425
    Compostela, GZ
    thanks for the ideas. :D
    I'll probably try something one of these days...
  6. jogy
    jogy TPF Noob!
    Apr 10, 2007
    Hi, I don't have your camera but whenever I have a problem with mine I always go to a great tech support site that help me deal with my troubleshooting support issues.
    If you don't find your camera, just go to the free live chat support and one of the expert will help you!
    Here is the page for Nikon Cameras support
    Good luck
    Jogy
  7. panocho
    panocho TPF Noob!
    Feb 7, 2005
    425
    Compostela, GZ
    thanks for the link. I'll try that!
