Problem with EOS Solution Disk
Discussion in 'Photography Beginners' Forum' started by R6_Dude, Jan 17, 2010.
  1. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    I can't seem to download this disk onto my computer. The disk does not mention any system requirements, but I pretty much have a brand new computer (reformatted) that I am planning to only use for photos.
    Its driving me nuts!
  2. nemopaice
    nemopaice TPF Noob!
    Jan 17, 2010
    90
    Ohio/N. Carolina
    You mean installing from the disk? any modern PC should work just fine. Have you gone to Canon's website and try to download it from there and install it?
    http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
  3. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    ^^^its not available on canon's website. I have no idea why it doesn't work. When I put in my bro in laws disk he got with his XSi (mine is a T1i) it works. His disk is ver. 28 and mine is 20.1 (more updated).
  4. nemopaice
    nemopaice TPF Noob!
    Jan 17, 2010
    90
    Ohio/N. Carolina
    I have the T1i also. Everything that's included on the solution disk in available on that site (the link I provided). Now that I know you have the T1i, here is the direct link to the download section. Canon EOS Digital Rebel T1i
    Under Driver/software section, select your OS from the drop down box. Then start downloading. Each item you download you will have to go back and re-select your OS. If you want what's on the disk then get the EOS Utility, Picture Style Editor, Original Data Security Tools (if on Windows), Canon RAW Codec, Digital Photo Professional, and ZoomBrowser EX. And of course the PDF manual if wanted/needed.
  5. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    ^^^^I saw that but they seem to be updates only.
  6. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    is there a program that you might think my comp is missing that will stop me from installing it?
    keep in mind that I recently reformatted and am running XP and no other programs.
  7. nemopaice
    nemopaice TPF Noob!
    Jan 17, 2010
    90
    Ohio/N. Carolina
    Yea only a couple are updates, but even the updates might work. When you try to install the update before you have anything installed on your computer, it will ask you to insert your disk to verify it. I would definitely give it a shot.
    There shouldn't be any program missing if you just recently reinstalled XP. did you go through all your XP updates. (the most daunting part about reinstalling)
  8. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    I think I know whats wrong. After 45 mins of downloading, RAW codec says that it can not install b/c I need XP SP2? I don't know what I have but I think its XP Professional. This can probably be the problem?
  9. DennyCrane
    DennyCrane No longer a newbie, moving up!
    Sep 11, 2009
    1,375
    34
    The arctic North Coast
    You need to go to Windows Update on your computer and let it update. If you're at SP1 (Service Pack 1), you have a LOT to get updated. Set it to automatic when it asks you and you will update to SP3.
  10. nemopaice
    nemopaice TPF Noob!
    Jan 17, 2010
    90
    Ohio/N. Carolina
    Yep, I kind of figured you'd need the updates after you reminded me about your reinstalling XP. It should keep your computer busy for a spell.
  11. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    ^^^thanks. Thats what I'm doing now. But I don't know why the manual doesn't show what the requirements are. I spent a good 3-4 hours trying to figure it out.
  12. DennyCrane
    Sep 11, 2009
    1,375
    34
    Consider this as a piece of luck... having an PC that's not updated is like leaving your car running with the door open in NY city. There's literally hundreds of security updates you'll be receiving from Microsoft.
canon eos digital solution disk download 24.1
canon eos digital solution disk ver 24.1
canon eos digital ver 24.1
canon eos digital version 24.1
canon eos solution disk v24.1
download canon eos digital solution disk ver 24.1
eos digital solution disk 24.1 download
eos digital solution disk version 24.1
installation error on canon solution disk
