problem with my camera..
Discussion in 'Digital Discussion & Q&A' started by tekzero, Jan 11, 2008.
  1. tekzero
    tekzero TPF Noob!
    Oct 28, 2004
    705
    4
    for some reason my camera wont snap any pics...its acting as if there is no memory card in the camera... the no card icon is blinking inside the viewfinder, but the card is in there .. i tried another card and i got the same thing, its driving me nuts i cant take any pictures... i had unloaded pix from a card onto my computer... unplugged it... next day i have this problem, any thoughts?
    camera is nikon d50
  2. H0LLYW00D
    H0LLYW00D TPF Noob!
    Oct 2, 2007
    46
    Calgary, Alberta, Canada
    try reseting the camera to factory defaults and then format the memory card and see if that helps.
  3. tekzero
    tekzero TPF Noob!
    Oct 28, 2004
    705
    4
    wow my back LCD wont even turn on, so i cant reformat...oye
  4. SCHNOOBS
    SCHNOOBS TPF Noob!
    Dec 29, 2007
    103
    T-Town Oklahoma
    I read about this awhile back and i'm doing my best to remember what it was. I don't think that it would be the camera, I remember that it had something to do with the memory card. go ahead try another one, I believe that will rectify the issue.
    if it doesn't make sure everthing is clean, nikon has an ungodly durability to them.
    if that does not work take it to your local camera shop (not retailers, they don't seem to know much).
    take out battery (hard reset) ?i wouldn't doubt it if you've alrady done that?
    if you're uploading the photo from camera to computer, it is beneficial for the life of your battery that you get a crad reader, reason is because there is only so many times you can recharge taht battery...
  5. tekzero
    tekzero TPF Noob!
    Oct 28, 2004
    705
    4
    schnoobs... i tried 2 dif mem cards, same thing, also tried 2 dif fully charged batteries...
    everything is clean... i called a Ritz and also a local place, both estimate around $175 for repair, but 6-8 weeks for an ETA of getting it back, ugh
  6. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,336
    16
    Caribbean
    Does the d50 use CF cards? If so, look inside the compartment and look for bent pins. Make sure if you have an aperature ring on the lens that it's on the auto setting too, I've freaked myself out a little bit before with my 50mm. I'm not sure why the LCD isn't working though, that would scare me a little bit.
  7. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,209
    236
    Los Angeles
    I was gonna suggest the same thing.
  8. TDSapp
    TDSapp TPF Noob!
    Jun 17, 2007
    24
    Frisco Texas
    I had the same type problem with my D70. Turned out to be the camera and had to be sent to Nikon for repair. There was a recall on the D70 so it did not cost anything. However, it was 4 to 5 weeks to get it back.
    I would suggest checking the NikonUSA web site and see of there is anything on there.
    Tim
  9. Mathias13
    Mathias13 TPF Noob!
    Oct 8, 2007
    219
    Vancouver BC
    there's a little switch on the top left side of the memory card that you can flip down to lock it...flip it down and flip it back up again to reset it
  10. Elapid
    Elapid TPF Noob!
    Dec 15, 2007
    6
    Did the D70 use a sensor made by Sony? Sony had a big recall of there 5.1 mp cameras due to a manufacturing defect. There was a class action suit that they had to get to force Sony to fix their problem. I heard that the same sensor was used on some Nikon cameras but didn't know which ones. You might want to see if your camera falls into this group. If it does, Sony will replace it free.
  11. TDSapp
    TDSapp TPF Noob!
    Jun 17, 2007
    24
    Frisco Texas
    From what I understand it was not a sensor issue. It would not read the cards and then it would not "boot up". Just the green memory light flashing and nothing else. At first it was a hit and miss on if it would work... Once booted it might take a couple shots and then start flashing again. I would then have to remove the battery from the camera to get it to shut off. It then got to where it just stopped working at all.
    Tim
  12. tekzero
    tekzero TPF Noob!
    Oct 28, 2004
    705
    4
    thanks all for the answers, after much troubleshooting, i am sending it to nikon directly, shold be a quick turnaround
schnoob construction tx
