Problem with pixels?
Discussion in 'Photography Beginners' Forum' started by heymickey, Apr 10, 2010.
  1. heymickey
    heymickey TPF Noob!
    Apr 10, 2010
    usa
    Hello,
    I've started running into some problems with my photos where there are spots with rather visible pixels - this happens especially in highlights on images. I've only really noticed this happening in the last couple of months. I attempted to find an unedited photo where I could try and show an area where this is happening so hopefully this will give you an idea of what I am talking about (the problem appears even stronger on the web).
    Is this something I can fix with the settings on my camera, better lighting, etc. or is there something wrong with the camera itself?
    Thank you for you help!!
    [​IMG]
  2. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    I'm not exactly sure what you're talking about, but it could just be noise. If the pictures were taken at a high ISO then they will end up noisy/grainy. That picture definitely has a noticeable amount of noise but I can't see what settings it was taken with.
  3. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    Pixel peeping can cause you to chase problems that aren't probems.
    If you are shooting JPEG.
    The JPEG image format converts the image sensor pixels into 8 pixel x 8 pixel squares.
    You are likely seeing the edges of those squares, not the actual pixels.
    Look closely in the brickwork and you can see the edges of the JPEG 8x8 pixel squares in this image.
    [​IMG]
  4. heymickey
    heymickey TPF Noob!
    Apr 10, 2010
    usa
    This is the information from that photo - device make: canon, device model, canon eos digital rebel xt, focal length 55, alpha channel 0, red eye 1, fnumber 5.6, exposure time 1/60
    I believe the photo I grabbed for the example was one that was just a quick shot using the automatic settings in low lighting so it was definitely a bit grainy. I've had this issue with other photos though, but it has only happened recently which is why I was thrown off by it showing up in sections of my photos.
