Problem with polarizer
Discussion in 'Photography Equipment & Products' started by Canon88, Dec 26, 2007.
  1. Canon88
    Canon88 TPF Noob!
    Dec 12, 2007
    15
    Denton, Texas.
    I seemed to have tightened my circular polarizer a little too tight on my canon 17-55mm f/2.8 IS USM lens and now cant seem to loosen it. Any suggestions??
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    try to loosen it without applying too much pressure ... if you have to increase the pressure onthe filter ring, try to do it not in 2 places, but more, and evenly distributed. that way the ring will deform less and will be easier to unscrew.
    Some shops also have devices to remove filters more easily. So you could ask in a shop.
  3. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Oddly enough they tighten up on their own some times, Mine did that the other day. I don't overtorque it when I put it on but I had to put some effort into removing it. As lame as it sounds, take the lens off the body and just turn it a little harder. Like alex_b said try to keep the pressure even.
  4. probe1957
    probe1957 TPF Noob!
    Dec 1, 2004
    48
    From my "another life" days as a camera repair student, they make wrenches specifically designed for removing stuck filters. Hopefully yours isn't stuck that badly.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    From my "other life" as Angus MacGyver if you put one of those thicker rubber bands on the ring of the filter you can apply much more torque without compression force on the filter ring which is probably what's preventing you getting it off at the moment.
    The harder you twist the more pressure you apply to the sides the more torque you need the harder you twist the more...
  6. johnmh
    johnmh TPF Noob!
    Oct 9, 2007
    102
    greater NYC
    Those plastic/rubber 'grabber' discs for opening jars are useful. Use with lens off the camera, lens face down on a flat surface with the disc between it and the lens/filter face. Surprised me.
  7. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Those wrenches suck. I have a set. I thought they would help with the exact problem the OP is asking about, but in the end all that would work was brute force. The problem is that the filter turns...very frustrating.
  8. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    To help prevent this in the future, you can use a pencil to draw some graphite onto the threads, which will act as lubrication and hopefully keep the filter from getting stuck.
  9. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Oops. Guess loctite red wasn't the right stuff...
    :er:
  10. Battou
    May 10, 2007
    7,997
    26
    :lmao::lmao:
  11. Tiberius47
    Tiberius47 TPF Noob!
    Oct 4, 2007
    742
    46
    Place the palm of your hand over the polariser.
    Close your hand slightly.
    Twist. That's what I do, works a charm.
