problem with Xs?
Discussion in 'Photography Beginners' Forum' started by jeljohns, Apr 27, 2009.
  1. jeljohns
    jeljohns TPF Noob!
    Feb 9, 2009
    58
    I am so frustrated with my Rebel Xs camera! Since I got the camera I have not been able to take a single picture that isn't soft/blurry or too dark. It doesn't matter what ISO or setting I have it on. Has anyone else had this problem with this camera? The only time it seems to work well is outside on a clear sunny day. I'm really annoyed that my P&S takes sharper, better pictures than a camera I paid $$$ for.
    Here is an example from this past weekend.
    [​IMG]
  2. raptorman
    raptorman TPF Noob!
    Apr 17, 2009
    47
    Can you post the EXIF data of that picture?
  3. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    Can you post your exposure info from that photo? In particular, the ISO, Shutter Speed, and Aperture. I ask because it looks like you have blur from camera shake, which usually means that your shutter speed was too slow.
    In particular, it looks like you were shooting in a rather low light situation -- indoors at night under flourescent lights. That's dimmer than you might expect, especially if you're using your kit lens, which is "slow" (meaning, doesn't collect light as well as some others). This is a common problem with indoor shots, and often your best bet is to either get a flash, or a faster lens (such as a 50mm f/1.8 or f/1.4, which will let you collect a lot more light in the same situations).
  4. jeljohns
    jeljohns TPF Noob!
    Feb 9, 2009
    58
    How do I find the data?
    I'm pretty sure the camera was in AV mode. f/4.0 (the lowest my lens would go) 800 ISO.
    It seems that even if I have it set to a high ISO and a wide aperture the shutter is still very slow so my pics are always blurry. Faster shutter speed and they are dark AND blurry.
  5. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,143
    2,943
    Chesterfield UK
    There is nothing wrong with your camera, it is user error, all you need is better understanding of exposure which will come with time, if you are using the kit lens inside you will not get good photos unless you use a flash
  6. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Getting faster lenses like the aforementioned 50mm 1.8 would help a lot. You can go all the way up to aperture 1.8 and get some fast shutter speeds, though your DOF will be quite small, but you can still get the shot. What it boils down to is that you dont have enough light when trying to shoot. The image is blurry because you have to shoot at a slow shutter speed to get proper exposure, as a result the slightest movement of your hand will make the picture appear blurry. You can choose a faster shutter to counteract the blurry photos, but then you dont have enough light because your shutter is opening and closing so fast that its not allowing enough light in to get a proper exposure, hence the dark image.
    A tip you can try is switching the camera to manual mode and using the pop up flash. Before taking the photo, drop your shutter speed down to 1/30, 1/15, 1/8 or whatever of a second. This way your flash can help you properly expose the subjects, but the slow shutter speed will help bring out the ambient lighting so the background doesnt go black. Its called dragging the shutter. The flash can help freeze some camera shake, but you need to hold really still and have your subjects do the same. Good luck!
  7. raptorman
    raptorman TPF Noob!
    Apr 17, 2009
    47
    Open your picture in Digital Photo Professional (came bundled with your Xs), right click on it and chose info.
  8. suki
    suki TPF Noob!
    Apr 17, 2009
    112
    Aurora, Colorado
    I'm not sure what it's called, because I keep getting the two mixed up, but it's 1/25 and in i believe Av mode (or Tv, those are the two I usually shoot with) and my pics will come out pretty clear, as long as i remember to focus first on the subject and then move to position.
    It took me a couple weeks to figure that out so just continue to play and shoot with the camera and practice different settings.
  9. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Its all dependent on the amount of available light...chances are your settings wont work for him.
  10. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    You're just struggling with understanding the camera settings. What I see is some vicious hand-shake with too slow of a shutter speed. A shutter speed of 1/25 isn't fast enough to compensate for movement in this case it seems. As a general rule, try to have your shutter speed 1/focal length. In other words, if you're shooting at 50mm have your shutter speed at least 1/50. I like to go a stop faster just because I hate goofing things up if I can avoid it. Also, if your lens has image stabilization (do you have the 18-55 IS kit lens?) make sure you have this enabled.
    A P&S camera does everything for you, that's why when you take a shot in adverse lighting it looks better than the images you're capturing with your DSLR right now. Once you understand exposure a little better you'll find that you can easily capture images that far exceed the quality of your P&S.
    Keep trying, don't give up. I know it can be frustrating at times.
  11. suki
    suki TPF Noob!
    Apr 17, 2009
    112
    Aurora, Colorado
    ahh yes. I have been shooting alot in natural/day light.
  12. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Tharmsen is right, but there is another strategy that can help with getting sharp shots. Try using the burst on your camera. You can just hold the shutter and it will take a few shots quickly. Sometimes this can be helpful and a sharp shot might sneak its way in there. Though I'm not a big fan of this "spray and pray" method, it's worth a shot.
