problem
Discussion in 'The Darkroom' started by fightheheathens, Jan 8, 2007.
  1. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    so, this is quite odd...
    i recently got stuff for developing B&W. I took a college corse on it about 1 year ago and i think that i am fairly good at developing and printing with B&W.
    additionally having run a good 2,000 B&W pictures through my camera in the last year, i think i should know what im doing when it comes to correct exposure blah blah blah.
    anywho, i cannot for the life of me get a good roll of Ilford Pan F + 50ISO
    in college, I mostly used HP5 and some T-max and i got really good results with it.
    I only did 2-3 rolls of the Pan F+ in college and all three rolls came out thin..IE it seemed like there was almost nothing there on the neg. almost clear but if held up to a dim light, or white wall you could see an image.
    When i developed these i had accidently left my Developer in the car over night and it may have froze, so i chalked it up to that.
    However, now that i have my own stuff, i have been developing and have run into this same problem again.
    I have developed some Tri-X 400 and HP5 with Ilfosol S and gotted the expected results. IE good full density negs
    however, i have done three rolls of Pan F + and gotten the same thin negs. it looks as if they were under exposed or under developed.
    I developed with Ilfosol S at the recomended time, temp, and concentration.
    6 min at 68 degrees with a 1+14 dilution
    Additionally i know for a fact that according to my camera, all of the images are properly exposed. I also know that my light meter works. A roll shot at a similar time (but HP5) came out fine.
    also my light meter gives the same exposure reading at f22 1/60 ISO 400 and f8 1/60 ISO 50
    So what the heck? it must be in the developing and i dont want to ruin more of my PanF trying to fix this, I have some pan f to develope that has some great shots on it that i might want to print and hang, but i dont want to be dissipointed because of thin negs.
    any suggestions or help would be awsome
  2. ahelg
    ahelg TPF Noob!
    Sep 12, 2004
    338
    Durham, UK
    Have you actually tried printing any of these negs to see if they produce a good photograph?
  3. ThomThomsk
    ThomThomsk TPF Noob!
    Oct 27, 2005
    441
    50ยบ north
    I had a very similar experience with Pan F and like you I followed the instructions. I settled on FP4+ as my standard film and so didn't really pursue the matter, but from what I read on APUG (where there are a few threads on this topic) it isn't unusual, Pan F is just low contrast. A lot of people treat it as a 25 ASA film.
    I suppose there are a couple of approaches you could take. First, proper film tests to determine the true film speed and development time for your equipment and method. Second, trial and error - try a roll at 25 ASA and see if you like it better, and/or try it at 50 ASA and add 20% to the development time, 25 ASA and add some development time, etc.
    Thom
  4. ahelg
    ahelg TPF Noob!
    Sep 12, 2004
    338
    Durham, UK
    If you are used to using HP5 and T-MAX and you are happy with the results they provide, then it's probably a good idea to stick to them. I find that it's often a good idea to find a certain film that you like and stick to that as you'll learn to know the film (hmm. learn to know it is a norwegian expression. I guess it doesn't translate well, but it basicly means that after a while you'll learn everythin there is to know about it).
  5. fightheheathens
    Aug 1, 2005
    1,011
    Berkeley
    i have tried printing and it is very tricky. but in the end, i felt the results were worth the vast ammount of effort and wasted paper i spent.
    I really like doing landscape in B&W and HP5 is normally too much grain for me.
    I have been happy with the T-max 100 but i would like to see what the PanF gives me.
    If i cant get the panF to work like i want it, ill probably stick to the T-max,
    but i have always had good results with the other Ilford films i use and you'll never know if there is a better film for you out there if you dont try
  6. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    Shoot the Pan-F at ISO 25 and increase the contrast a bit when you print.
  7. Majik Imaje
    Majik Imaje TPF Noob!
    Feb 15, 2007
    285
    Point Hope Alaska
    .. .. sorta figured the problem out!
    your quote: however, i have done three rolls of Pan F + and gotten the same thin negs. it looks as if they were under exposed or under developed.
    well it is either one or the other.. ! or maybe neither. like one person said. or asked.. have you tried to print any of them ?
    also, I am reminded of a very famous photographer who said.. concerning issues such as this.
    Pick one film ! stick with it.. !
    I remember the first time I saw a "correctly" exposed b&w negative. I was astonished that it wasn't THICK like mine were.
    just a few tips.. ! go with what works for you and stick with it!
