Problems with burst settings ???
Discussion in 'General Shop Talk' started by BAHAMAS, Jul 3, 2010.
  1. BAHAMAS
    BAHAMAS TPF Noob!
    Jul 3, 2010
    Hi I am somewhat puzzled – as the other day I bought 2 Sony cameras to see which one would be a good all around pocket camera, they were the Sony H55 & the Sony HX5.
    Going by the stats on the internet both of the cameras were said to do 10 fps but the H55 sounds like about 3 fps .
    Can someone please explain this to & if there is a certain section in the cameras settings that will let the H55 do a faster burst rate.
    Here is one of the comparison websites that I looked at.
    : Digital Photography Review
    Thank you Craig
  2. KmH
    Apr 9, 2009
    39,505
    5,331
    Iowa
    Your link is hosed.
    From looking at the specs for each camera, I believe that is 10x zoom, not a burst rate of 10 frames per second.
    In fact, the specs list at DP Review doesn't show a burst rate of any speed.
    Here the "Continuous Mode/Framers/Second" is just a blank box:
    http://www.imaging-resource.com/PRODS/H55/H55DAT.HTM
    Here under "DRIVE SYSTEM" it says the burst mode is 1.84 fps @14.1 MP (maximum 4 shots)
    http://www.sonystyle.com/webapp/wcs...&productId=8198552921666027345#specifications
    Here again, no fps rate is listed in the specs:
    http://reviews.cnet.com/digital-cam...c/4507-6501_7-33997872.html?tag=mncolBtm;rnav
    Canon's 1D MKIV can do aboout 10 fps. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=19584
  3. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    I have a feeling you will need a lower resolution to do faster burst. If you go with high res, it it such a large file that the internal memory cant handle it.
burst settings
changin burst settings in sony camara
h55 burst fps
what are burst settings?
