PROBLEMS WITH SUNSETS
Discussion in 'Beyond the Basics' started by THE FLASH, Oct 15, 2006.
  1. THE FLASH
    THE FLASH TPF Noob!
    Oct 14, 2006
    12
    South West Wales. U.K.
    Need some help here please, I use a Panasonic Lumix FZ30 There is no programme on the camera, as far as I can see, to use to get some good sunset photos Any ideas how to improve my either blown out images or totally black ones. Any help appreciated, thanks
  2. Azuth
    Azuth TPF Noob!
    Dec 25, 2005
    262
    Sydney 'strailya
    Use manual mode. Use the light meter. Set the camera to about F8 and a speed that the camera thinks will expose the image correctly. Shoot one or two speeds either side of that.
    It's digital, surely you can on the screen if your image is exposed correctly?
    You can't have all the detail in the sunset & in a dark foreground at the same time though. They don't make camera's that do that. If the foreground close to you is interesting you can fire a burst of flash to create a different effect.
  3. THE FLASH
    THE FLASH TPF Noob!
    Oct 14, 2006
    12
    Thanks Azuth, will give that a try tomorrow evening Weather permitting
  4. j_mcquillen
    j_mcquillen TPF Noob!
    Oct 3, 2004
    290
    Northumberland, UK
    You can if you use Neutral Density Graduated filters, or combine a number of different exposures of the same scene in photoshop (known as High Dynamic Range or HDR) :D
