Product Photography- pet bowls
Discussion in 'Beyond the Basics' started by jjenniebug, Jun 3, 2010.
  1. jjenniebug
    jjenniebug TPF Noob!
    Jun 3, 2010
    Hi there,
    I am new to this forum but I am excited about the opportunity to get some great advice from you members!
    I need to take better product photography of my pet bowls. I have a Nikon D60, tripod, 2 umbrella lights and a white muslin backdrop. I am having problems getting rid of the shadows created by the wrinkles in my backdrop. I have adjusted the contrast levels in Photoshop but as you can see it still looks bad.
    Any thoughts on what I should try?
    Thanks in advance!!
    Jennie
    [​IMG]
    [​IMG]
  2. redtippmann
    redtippmann TPF Noob!
    Aug 19, 2008
    706
    6
    Athens, Ohio
    What type of light are you using, continuous or flash?
    BTW: It looks like you are getting 2 color lights. Make sure to either turn your house lights off or gel the photography lights to match.
  3. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    good flash heads are what you need. probably three, each with a softbox or umbrella. a more experienced person can give you better specifics than i can.
  4. AnneRiceBowl
    AnneRiceBowl TPF Noob!
    Mar 27, 2010
    162
    Papillion, NE, USA
    They seem a little OOF to me.
  5. redtippmann
    Aug 19, 2008
    706
    6
    Athens, Ohio
    You could probably do it with one flash (with an incandescent gel). Shoot it through a 24x32" softbox. Then use a 100W (or greater) regular light for the background.
  6. Don Kondra
    Don Kondra Been spending a lot of time on here!
    Dec 11, 2007
    1,516
    617
    Saskatoon, Saskatchewan, Canada
    A seamless paper backdrop will get rid of the wrinkles, then you can work on the lighting :)
    Cheers, Don
  7. jjenniebug
    Jun 3, 2010
    Wonderful- thank you all! I will try the paper backdrop first and then when I can afford more lighting props I'll look into the flashes and softbox.
    Is there anything else I can do in Photoshop to minimize the shadows/ wrinkles with the pics I already have or are they toast? I have PS Elements 5.0- nothing fancy, I know :sillysmi:
    Red Tippmann, I am using continuous lighting but also had the overhead light on which explains the two colors of light- you guys are good!
    Jennie
  8. KmH
    Apr 9, 2009
    40,529
    5,540
    Iowa
    I used PSE7, but I selected the product with the Quick Selection tool, then at the top of the workspace clicked on Select > Inverse, so it selected the background only. Then I clicked on Layer > Newe Adjustment layer > Brightness/Contrast and increased to Brightness slider as high as it would go and clicked ok. I then reselected the background layer and then clicked on Enhance > Unsharp Mask. Then sharpen to your taste.
    [​IMG]
  9. redtippmann
    Aug 19, 2008
    706
    6
    Athens, Ohio
    One thing you might want to do is go to Home depot and see if you can get a more powerful bulb. But not too powerful because you might melt your umbrella!
    BTW: I think KMH did a nice job!
  10. KmH
    Apr 9, 2009
    40,529
    5,540
    Iowa
    If you look close at the edges you can see where I saved time by not cleaning up the selection.
    The point was to illustrate some alternative editing techniques.
    It's always better to get it right in the camera.
  11. jjenniebug
    Jun 3, 2010
    Wow KMH- that looks great! For what I need the pics for (online listings) the edges are fine as they are. At least this will let me use the pics I already have- or make them look much better.
    Thanks so much ;)
    Red Tippmann- I'll try the stronger bulb- my umbrellas are not the highest quality so yes I would worry about them melting but I'll keep an eye on them! Thank to you too! :D
  12. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,143
    2,943
    Chesterfield UK
    Your white backdrop needs more light, it should be about one stop brighter than the subject, but your focusing is a bigger issue, don't rely on photoshop get it right in the studio
nikon d60 product photography
