Proper Holding Techniques
Discussion in 'Beyond the Basics' started by pdechavez, Apr 11, 2009.
  1. pdechavez
    pdechavez TPF Noob!
    Apr 11, 2009
    6
    Canada
    So I have a Nikon D300 and a Nikkor 105mm Micro VR.
    Is it safe to hold the lens barrell connected to the camera? What if i have heavier lenses? I believe that if the lens is heavy, it is safe to carry the lens barrell instead of the camera.
  2. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    Are you asking if it's ok to carry the entire camera-lens unit by holding only the lens?
    In general, I'd say the answer is yes. Most lenses have a good solid mount and shouldn't give you any problem -- I hold my D40 by the barrel of my 18-200 all the time.
    The only time I'd worry is if you have a cheap lens with a plastic mount -- you might end up putting a lot of stress on it over time. But, I've never actually seen this be a problem, it's just conjecture from me.
  3. pdechavez
    pdechavez TPF Noob!
    Apr 11, 2009
    6
    Canada
    that's cool. i just want to know since my camera is expensive and heavy. I've been shooting for years and never know these small things.
  4. LuckySo-n-So
    LuckySo-n-So TPF Noob!
    Feb 2, 2009
    449
    Baton Rouge, LA
    Whatever the case, make sure that the strap is around your neck. Especially if you have the coordination and grace of an elephant. I posess such dexterity and fluidity of movement. If it can be broken, I'm sure I can find a way to inadvertantly break it.
    I find that duct tape works too.
  5. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    If it is a heavy lens then yes by the lens. If it is small lens you cant carry it by the lens anyhow.
  6. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    You can pretty much carry it by the lens or camera. When you get into larger lenses they often come with a tripod caller to support the camera by the lens, rather than the camera, just for balance, but cameras and lenses are designed to support each other, so carry your camera in the the way that is most comfortable for you.
  7. dl4449
    dl4449 TPF Noob!
    Jun 7, 2008
    264
    San Jose,Ca
    +1 on having the strap around your neck
    Troy
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Or if you are holding it in your hand, double wrap your strap around your wrist. I get looks when people see me supporting the camera with one finger under the grip in my right hand. "Aren't you worried about dropping it?" So I let go, and the strap tightens around my wrist and catches it 10cm further down.
  9. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    I carry my EF by my Vivitar 400 all the time, periodically I also do the same with my FD 100-200 but never anything smaller
bullhead holding tool
proper bullhead holding techniques
proper camera holding technique
proper holding
proper holding techniques
