PS question for Wedding Photos
Discussion in 'Photography Beginners' Forum' started by Thru_These_Eyes, May 22, 2009.
  1. Thru_These_Eyes
    Thru_These_Eyes TPF Noob!
    Jun 11, 2007
    138
    Ann Arbor, MI
    I photographed a wedding today and i am looking at the pictures on my computer now and I am wondering if there is any way to darken up the Bride's skin tones? She is VERY white and it almost takes away from the pictures...is there anyway to make this happen? I am still learning PS and thought maybe someone would have an idea on how to work some magic on her skin? Gracias
  2. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Once the image is in PS, there are several options. Probably the best and certainly the most controlable is to create an Adjustment Layer, usually Curves but Levels will work, and use a Layer Mask to limit the Adjustment Layer's effect to just the areas (i.e skin and perhaps dress) you want. Basically:
    1. Create a Levels Adjustment Layer (click the appropriate button at the bottom of the layers panel or access the Layers menu and select Adjustment Layer)
    2. Adjust the levels so that the skin looks the way you want. You don't have to be precise at this point, you can change it later. Also, do worry that this is also changing everything else in the picture.
    3. PS adds a Layer Mask to Adjustment Layers by default and its active by default. With the new Adjustment Layer selected in the Layers panel, select black as the foreground color (you can only select black and white) and use the Paint Bucket to fill the layer (actually the Layer Mask) with black. This will seem to disable the Adjustment Layer; don't worry.
    4. Now select white as the foreground color and select the Paint Brush. Adjust the brush tip size appropriately and set the softness to a middle value (right click on the image if using Windows to access the adjustment dialog, Opt-click on Mac) and then paint white over the skin and other areas where you want the Adjustment Layer to take effect.
    5. You can then go back to the Adjustment Layers controls and change the values to increase or decrease the adjustment until you get the result you want.
    If saved as a PSD, the layers save with the file and can be readjusted at any future time.
  3. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    Nice write up Dwig!
  4. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    I'd like to see an example of what you're talking about. Can you post one?
