PS won't open my RAW files form my D90???
Discussion in 'Beyond the Basics' started by gl600, Jan 30, 2010.
  1. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    Middle East and Canada
    Hey,
    I just got a new D90 and I am trying to open some of the NEF (RAW) files in Photoshop but they won't open. It just says "Could not complete your request because of a program error".
    I'm using cs4 extended.
    PS will open raw files from my D60 (even when I use the same SD card). I have tried formatting the card, no luck.
    Any idea's?
    Thanks!
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Do you have the latest Adobe Camera RAW?
  3. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    how do i check?
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I have Lightroom, so it may be a little different for you.
    If I go to Help -> About, it tells me what camera raw I have installed (which is 5.6).
    Go to the support area of abode.com and see if there is a newer version than what you have installed.
    There should be some kind of update check in PS too though...
  5. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    166
    San Diego, CA (RB)
    Just got to the Adobe website and download the most up to date camera raw for the camera you are using. That will fix your issue.
  6. Mike_E
    Jan 26, 2007
    5,327
    266
    Update your software. You may have to manually add the D90.
    Try a trial of Capture NX2. You can export as a TIFF and go around the whole problem.
    Try the NX2 anyway, the lens distortion correction is really nice and a lot of the other corrections are easier and in some ways even better than CS4.
  7. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    And the color is accurate in NX2.
  8. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    I had version 5.0.0.178
    I updated to 5.6... and it's all good.
    thanks!
  9. kkamin
    kkamin TPF Noob!
    Aug 25, 2009
    514
    17
    Minneapolis
    Covert your files to DNGs first. As you probably know it is Adobe's raw file format. I like them because they don't use sidecar files. You can download the converter for free from adobe Adobe - Digital Negative (DNG) The download link is in the upper right hand corner of the page.
    edit: oh, you solved it, never mind. @_@
  10. evcarter
    evcarter TPF Noob!
    Sep 25, 2010
    mississippi
    I have a legally purchased CS4 extended and I have downloaded camera raw update but get "file access denied" when I try to unzip the file. I am really frustrated that I cannot open my raw files! ANY help is greatly appreciated!!
  11. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    Follow the instructions on the Adobe site for installing the plugin, or as mentioned, use the free DNG converter for your raw files. H
