Putting my sig. on a picture?
Discussion in 'Graphics Programs and Photo Gallery' started by Ghoste, Aug 12, 2005.
  1. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    I've seen people with what look like their actual signature on a photo. How do they do this to a digital picture? If not what fonts are good for making look like a signature? Thanks guys.
  2. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Can't you just write your signature with pen on white paper, scan it and remove all the white with a color select tool and copy the sig onto a new layer above the picture.
  3. vonDrehle
    vonDrehle TPF Noob!
    Jun 27, 2005
    430
    6
    North Carolina
    If you do it like that I would use a black sharpie or something like that. A Pen would most likely end up very hard choppy after trying to get rid of the white. If you have a PDA you might be able to e-mail it to yourself. There are some things I've seen that allow you to have your handwriting on your screen, not sure who makes them or anything about them though. But I wouldn't want to worry about buying something like that just to get your exact signature on some photos.
    You can look at all of these fonts for some you like...
    http://www.dafont.com/en/theme.php?cat=601
    http://www.dafont.com/en/theme.php?cat=602
    http://www.dafont.com/en/theme.php?cat=603
    http://www.dafont.com/en/theme.php?cat=604
    http://www.dafont.com/en/theme.php?cat=605
    http://www.dafont.com/en/theme.php?cat=607
    (Those are the categories under the script header minus the graffiti)
  4. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    Wacom (www.wacom.com) have a range of tablets that you can write on and use as your mouse that are really great. That is if you're looking into that. It's great to use when you're painting in PS (or signing your name) Although it does get a little bit of getting used to.
    Also you can use it with other applications like Microsoft Word. It can be a little cumbersome sometimes but get used to it and use your mouse at the same time well and it can be great. Plus Word is able to convert it into typed text very very well I've found... but I've got pretty neat handwriting so I guess that helps.
  5. Dweller
    Dweller Inconspicuous Supporter
    Apr 19, 2004
    668
    Portland, Oregon
    here is an article I found on the subject. I have not tried it yet but it covers a couple of ways of doing it, including scanning an actual signature and applying it.
    Article here.
  6. hobbes28
    hobbes28 Incredible Supporting Member
    Jul 10, 2004
    4,807
    41
    at work...
    All you have to do is sign your name to a piece of paper with a dark pen, I use a shapie. Then you scan it in and make your signature into a brush and stamp it on your pictures. There is an article about it on the forum here...lemme do some searching and show you how.
  7. hobbes28
    Jul 10, 2004
    4,807
    41
    at work...
    • Like Like x 1
  8. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    Ok, well, I got my sig on the computer. I'm just trying to figure out how to do this easily. I need to just cut the letters out. You can see where I just quickly lassoed out the sig. I suck really bad at lassoing. Is there an easy way to get the sig out. I just need it cut all the way out so it the photo will go all the way up to the letters. Or someone else could do it for me ;) Haha, thanks guys.
    [​IMG]
  9. hobbes28
    Jul 10, 2004
    4,807
    41
    at work...
    Just do a select color range, put the dropper on the white, select inverse, and you have your sig selected to use as the brush. ;)
  10. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    Thanks Hobbes! I love it.
    [​IMG]
  11. PhotoB
    PhotoB TPF Noob!
    Aug 4, 2005
    78
    Chicago Suburbs
    nice! :thumbup:
  12. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    hmmmm, i was told never to put a signiture on your computer or online. if i was a good hacker, think of all the things i could put that signiture on.....
