BuZzZeRkEr
- Joined
- Nov 26, 2007
- Messages
- 436
- Reaction score
- 0
- Location
- Va
- Can others edit my Photos
- Photos NOT OK to edit
Must have? or cheaper alternative? (professional wedding use)
I have a well used Quantum Turbo pack and a couple Nikon SD-8a packs that fast cycle my flashes like the Quantum Turbo with 6 AA batteries. If using Nikon SB28, SB80, or SB-800 flashes, these little packs fit in a shirt pocket and cycle in about 1.5 seconds. To increase the number of flashes I modded the SD-8 packs by increasing the battery capacity, they then just about equal the quantum for flashes per charge. The SD-8 runs as little as $140 or a non-Nikon knock-off from Hong Kong runs about $40 plus another $40 for the mod. Pix of my modification are at: http://www.pbase.com/jstuedle/diy_stuff
For ruggedness and durability the Quantum can't be beat though. I only use my modded packs on light stands. The SD-8a un-modded with 6 AA's for events where I need fast recycling and anticipate under 250 frames. And the Quantum Turbo for events that require both fast cycling and high frame count. If you don't need the fast cycling at all, then Al Jacobs makes something he calls the black box. His site is at: http://www.aljacobs.com/THE BLACK BOX.htm
Hope this helps, good luck.
