Question about 85mm f1.4 for portaits
Discussion in 'Photography Beginners' Forum' started by Lazy Photographer, Jun 29, 2010.
  1. Lazy Photographer
    Lazy Photographer TPF Noob!
    Jul 4, 2009
    648
    5
    Toronto, Canada
    I keep hearing that the Canon 85mm F1.8 is an excellent lens for portraits. But are we talking full frame or APS-C sensor? On my camera an 85mm lens would be 136mm. For my camera I'd be looking at a 50mm lens if I wanted something close to 85mm, right?
    I'm considering picking up a lens that would serve a dual purpose for portraits and macro. wondering what would work nice for both. The 50mm F1.4 isn't that expensive. Would that suit, do you think?
    Any thoughts or advice would be appreciated as always.
    Here's a shot from the weekend.
    [​IMG]
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,232
    15,105
    USA
    Portrait lenses and macro lenses are usually quite different animals. Some of the world's absolute best "portrait" lenses, like Nikon's 85mm f/1.4 AF-D lens have sharp central areas and softer corners at the wide f/stops like f/1.4 all the way down to f/4...and also some light fall-off too. Some of the world's best macro lenses have absolutely brutally sharp, neutral image rendering that is quite unflattering to people--some of the new Zeiss macro lenses are like this, with imaging charactertistics that are, IMHO, very people UN-friendly.
    Full-frame and APS-C are very different camera formats. On 1.6x Canon, you absolutely must position the camera much farther away from a subject than with a FF camera. With an 85mm lens on FF, you get an 8.5 foot tall field of view at 20 feet, but with a 1.6x Canon body, the camera must be 34.5 feet away to get the same field of view. What that means is that, to photograph a half-body pose with a 1.6x Canon body, the camera-to-subject distance is far enough that the 85mm starts to show rather deep depth of field...it's hard to interpret the difference by just looking at depth of field charts, and the "mental" or "visual" or "quantitative" differences between APS-C and FF are not as apparent from the DOF charts as they are from looking at actual photographs.
    Look at the photo you posted above...see that deep depth of field? What's the focal length and f/stop you used? ANyway....long story shorter--I do not think a 50mm is a good portrait lens, nor is it a good macro length. If you want an affordable macro lens with nice bokeh, the Tamron 90mm /2.8 macro is a better lens than the Canon 100/2.8 USM Macro. Sigma's 150mm 2.8 and Tamron's 180/2.8 macro both have lovely bokeh and make very pretty images. The problem with macro lenses is that at portrait distances like 6,7,8,9,10,15,20,30,40 feet (seriously, you'll be shooting at 40 feet with a 150 macro more often than you might anticipate on 1.6x), macro lenses have very,very,very hair-trigger focusing travel, and the slightest mis-aiming of the AF bracket, or the slightest bit of carelessness, and the subject will be out of focus in the final images much more often than if you were shooting with a field lens, ie, a non-macro design, like the Canon 85/1.8. Macro lenses are optimized for focusing at close distances, and beyond around 2 meters, the vast majority of macro lenses have very few degrees of focusing all the way to Infinity, and that design characteristic can cause some serious problems with most AF systems, and a macro lens used at say 10-20-25 feet is often not going to focus accurately enough to shoot moving subjects with more than about 75% success rate--you can have 25% or 30% out of focus, useless shots in Continuous AF, and even in Single, the reality is that a macro lens can be a real PITA unless you're working inside of six feet or so...
  3. Lazy Photographer
    Jul 4, 2009
    648
    5
    Toronto, Canada
    Seriously, Derrel, I can't thank you enough for the excellent explanation. I really learned something here. I have very little knowledge or experience with macro and portrait so this was quite enlightening. Maybe I'll rent a couple of lenses to try out first, along with reading up on this more. Thanks again.
    Oh, almost forgot, the above image was shot at F8 at 17mm. When walking around I usually leave it at F8 because the reviews claim my lens is sharpest at that aperture. The lady crossing the street happened so fast I had time only to swing around and snap her on the quick.
  4. Fedaykin
    Fedaykin TPF Noob!
    Mar 30, 2010
    426
    San Juan, PR
    Well, Derrel pretty much said it all. I just want to add that it's spelled Tamron, not "Tameron(in your sig).
  5. AlexL
    AlexL TPF Noob!
    May 16, 2010
    427
    Washington, DC
    Was thinking of 50mm 1.4 upgrade since I was happy with the 50mm 1.8. But i think after this post, I should do more research :)
  6. sovietdoc
    sovietdoc No longer a newbie, moving up!
    Jun 12, 2010
    1,140
    75
    rest of the world
    Derrel said it all. I've seen what Tamron 90mm f/2.8 macro can do and I was even thinking about saving for it at some point. It's an amazing lens for macro.
    I shoot my portraits at 85mm on my 17-85 EF-S. If I understand it right, doesn't mater if lens is EF-S, the focal distances are still multipied by crop factor?
    Assuming my ef-s lens is still multiplied by 1.6, so is that tamron, I'd befinitely recommend it as a portrait/macro lens based on how I used mine at 85mm and seeing what that tamron can do..
  7. edouble
    edouble TPF Noob!
    May 24, 2009
    732
    10
    NEPA
    Excellent write up Derrel. Thanks for sharing.
  8. Lazy Photographer
    Jul 4, 2009
    648
    5
    Toronto, Canada
    Really? And here I thought it was a typo on the lens hood. :) Thanks. I realized my mistake a while ago but still haven't gotten around to correcting it.
