Question about Aperture software.
Discussion in 'Photography Equipment & Products' started by table1349, Sep 23, 2008.
  1. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    My wife has finally, after many, many, many, (did I mention many), years decided to go with a Mac laptop. Obviously that opens the door to getting a Mac home computer now. :D :D :D.
    My question is for those Mac users with Aperture. I am curious as to its good points, bad points, useability etc. I am also curious if there is any other software out there for the Mac that you might suggest instead of Aperture for initial editing of RAW files.
  2. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    The best 3 apps of this sort are:
    1. Capture One
    2. Adobe LightRoom
    3. Aperture
    Aperture's bad points:
    1. It bogs down unbearably after more than about 6 or 7 image adjustments - to a single image. So for the first 5 slider adjustments it's very fast! The next 3 to 5 bogs it down so that it's nearly unusable. Then next 3 to 5 adjustment synch it and you're waiting 30 sec. to 2 min. for updates. And that's with the newest version!
    2. There's no way to edit directly. You cannot create your own workflow by dragging a few images off a card and then edit the files. You MUST import everything you intent to touch into a special folder. I personally hate that. If you like that method tho ten it's not a downside.
    Aperture's good points:
    1. For simple edits it's very smooth and speedy,
    2. It's stable,
    3. It's perfect for importing, sorting, and rating images. (I think that's it's primary function and they nailed it!)
    4. It has a neat-o GUI.
    5. It has a plug-in architecture that is actually used by 3rd party devs.
  3. table1349
    Sep 9, 2006
    4
    Thanks,
    Now for the down side. Someone posted some of the new things about the upcoming CS4. Or should that be CS$$$$. I will probably end up with that for final post production. Oh my aching wallet.
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    btw...
    Just so you know...
    You can download Lightroom 2 and try it out for free for 30 days. Something to consider before you make a decision. Personally, I like LR 2 the best.. although I do still use Capture One for certain cases.
  5. Bifurcator
    Jun 1, 2008
    3,312
    Japan
    Yeah, it's a pretty close call between LR and Cap1. I like Cap1 a little better because the RAW files on initial display just sparkle and usually need very little editing. In the others there seems to be allot less intuitive automation.
    But that's the only reason really. :D
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    So again, no one talks about Bibble Pro ;)
    My weapon of choice ;) .. and it works on so many platforms ...
