Question about exposure correction in RAW
Discussion in 'Beyond the Basics' started by Jon_Are, May 13, 2009.
  1. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    I'm not exactly sure how to phrase this question, but I'll try:
    Say I have two lenses that I am using to shoot in a relatively low-light setting (indoors during the day, for example). Lens A is a 3.5 aperture, Lens B is 1.8.
    So I first shoot with the 1.8 and find that I can attain correct exposure with a shutter speed of 60. This tells me, of course, that my 3.5 will be inadequate for this shot. (I know I can bump up the ISO, but that is not relevant to my question)
    Suppose I pop the 3.5 onto the body and take an identical shot using the same settings (except using 3.5 instead of 1.8). So now I have my shot and it is underexposed.
    Because I shot this in RAW, I open my editor and correct the exposure in this image.
    My question is this: Will my exposure-corrected 3.5 image be of the same quality as my 1.8 image which was shot with the correct exposure to begin with? If not, will the difference be obvious, or very slight?
    Thanks,
    Jon
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Why not try it yourself and see?
    When you increase the 'exposure' in post processing, the quality certainly gets worse. This is often where you get problems with digital noise as well.
    Sure, you do have some freedom to adjust the exposure slider...but it's up to you to decide how much adjustment and quality loss is acceptable in your images.
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I am not an expert on this. But this is what I had in mind. Please correct me if I am wrong.
    First, I will look at the histogram. If the histogram of the underexposed shot shift too much to the left to a point that a lot of blackout shadow, you cannot correct it via any software since details are lost. As a result, the wider aperture shots will look better. How much better depends on the amount of blackout shadow.
  4. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    It's very much dependent on the quality of your image rendering when you're underexposed. This varies camera to camera.
    I've found that shooting ISO 100 with my XTi, I can underexpose a shot by about 3/4ths of a stop and sometimes a bit more and have an image that is workable some of the time. I can routinely (and have to routinely) bump an image 1/3rd of a stop or so for exposure correction. I have once gotten a workable image where I had to bump the exposure nearly 2 stops. Most of the time the results are trash bin material.
    It will be noisy and you'll have to deal with that. But 1 to 3.5 is 2 stops? that's going to be rough.
  5. Moon Baby
    Moon Baby TPF Noob!
    Apr 7, 2009
    69
    Panama City, FL
    There is a noticeable image quality shift when adjusting raw files 1-2stops. It also depends on how much shadows are present. I have a 5D and even adjusting raws by one stop can leave some very noticeable noise.
  6. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It's usually best to have more exposure than you need (without clipping the highlights) and then adjust down.
    Expose Right
  7. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    "Underexpose" is an imprecise word -- it just means that your exposure is darker than you would have liked.
    It is possible that you may have severely underexposed, in which case the shadows in your image may have become fully black. No amount of exposure tweaking in ACR (or some other raw converter) will be able to bring back the detail which you lost in those shadows.
    On the other hand, you may have just been darker than you wanted, but no shadows were lost. In this case, you can tweak the exposure and probably make things look good.
    There are exact parallels for hilights and overexposure.
    So, the answer is -- it depends on the scene and light which you are photographing. But I wouldn't count on it! If you underexpose (or heck, even if you expose as well as possible), there is still a good chance that you may have some clipping, especially in a high dynamic-range scene.
  8. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    The digital sensor record more data in the brither tones than it does in the darker tones. So when you underexpose and try to lighten an image, you have less information, han if the image correctly exposed. That being said, at low ISO I can easily pull a full stop or more out of my Pentax K10 or K20, and At higher ISO's, can pull up to a stop.
  9. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    As a general rule you always want to expose properly in camera. Relying on correcting for a huge error (yeah, 1-1.5 stops is considered a pretty huge error... lol), and you are going to increase the noise in the darker areas to a point that it will be easily visible to the naked eye, and not at pixel-peeper level either.
    I can pull 3 stops out, it will just look like crap. In the end, just because one can do something doesn't mean this is the best way.
  10. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    I will. But this discussion gave me more insight into the subject than just a test would, as I anticipated.
    Yeah, I expected as much. (and this is the bottom-line answer I was in search of)
    Jon
  11. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    "Pushing" the exposure in post will yield results similar to having used a higher ISO when you take the picture. How similar will depend on a variety of factors including the flexibility of the RAW converter and the skill you have.
    If you make the real test, which you should, inclulde a shot at the higher ISO as well as the two proposed in your Gedankenversuch. Shot a set of 3 shots:
    1: f/2.0 @ 1/60 @ ISO 200 - adjusting lighting to make this the "correct" exposure
    2: f/4.0 @ 1/60 @ ISO 200 - 2 stops under exposed
    3: f/4.0 @ 1/60 @ ISO 800 - correct exposer again.
    Use the same lens for all 3 to avoid lens specific differences in exposure and contrast. Also shoot RAW for all 3. Convert the RAW images for #1 and #3 using the same basic settings; the converter's defaults are a good choice. The one thing you probably want to override is the noise reduction. Set this to zero reduction for both luminance and chroma.
    Now convert #2 making you own adjustments to match #1 and #3 as closely as you can. You'll probably need to boost the "exposure" and, most likely, reduce the color saturation. Don't make any changes in any noise (leave as zero) or sharpness (leave the same default used for #1 & #2).
    You'll find there's no such thing as a free lunch. "Pushing" the exosure in post will, at best, match the results of using the higher ISO in camera.
  12. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    Well, the reason I originally asked the question was to determine if I could get comparable results using my 3.5 zoom (and adjusting exposure in PP) as opposed to switching lenses to the 1.8 prime. I was trying to get away with being lazy.
    As I suspected, it seems the quality would not be as good. The key, I'm learning, is to get it (the exposure) right the first time.
    Jon
