Question about HDR and movement
Discussion in 'Photography Beginners' Forum' started by rodman, Apr 16, 2009.
  1. rodman
    rodman TPF Noob!
    Feb 2, 2009
    82
    Garden Grove, CA
    I understand the basic concept of producing HDR images/pictures.
    But how do people get these type of results:
    [​IMG]
    When there are people moving?
  2. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    30
    Brooklyn, NY
    im guessing one RAW shot and bracket in PP.
  3. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Those are made by processing one RAW three (or more) times, with different settings.
    In most cases, I think you could get the same results without having to process it three times. (You could do the same thing with some curves adjustments, and some dodging & burning if it needed it.)
    If you really want HDR, I think it would be better to do it the "right" way, with more than one exposure. Notice in this example that the highlights are blown, and the shadows don't really look like they have any detail. A "real" HDR wouldn't have those problems.
  4. SlimPaul
    SlimPaul TPF Noob!
    Nov 7, 2008
    437
    Doesn't look like a real HDR to me.
  5. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Its not real HDR.
    HDR + movement = not possible. (unless you want the motion of course).
    This is simply tone mapped from one image... or just processed in a different way... its common now for people to assume any kind of over processing is HDR. There really are lots of way to increase range in an image.
  6. Overread
    May 1, 2008
    23,679
    4,027
    UK - England
    The only way I could think of HDR being done with movement would be to have the moving subect moving out of the frame area - that way you take the first shot exposed for the main subject - it then moves out of frame and you take the remaining shots needed for the other areas.
    Then you paste the subject over the rest of the shots in editing (or more easily use a layermask to place the subject with the other shots). The only area this could be tricky with would be the shadow of the subject since you could not get an exposure correct for that area specificaly (though a later shot would have that shadowed area exposed well it would lack the shadow feature - though creative editing might fix this problem).
hdr movement
