Question about Manual mode
Discussion in 'Photography Beginners' Forum' started by Jon_Are, Aug 10, 2009.
  1. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    Say I manually set for f8 and 1/500, then take a shot.
    Now I want to take a second, similar shot with the same settings. I go to frame my shot, and the camera is no longer on f8 and 1/500.
    So, with each image I have to re-set my manual settings? Is this normal behavior?
    I ask because I would have thought that, in manual mode, the settings won't change until I change them (or switch out of manual).
    Thanks,
    Jon
  2. Opher
    Opher TPF Noob!
    Aug 7, 2009
    448
    5
    Kitchener ON
    I dont think it is normal. I just tested my Canon XS and it keeps the setting between pictures and when i come back to manual from shutter priority. Dont know about Nikons.
  3. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    i use canon so dunno bout nikon... but mine don't switch btwn shots...
  4. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    You're right, manual should keep the same shutter and aperture settings until you change them (even if you turn the camera off and back on, or go from manual to another mode and back).
    Does this happen every time? Is there any consistency or pattern to when this happens or how much the settings have changed?
  5. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    You mean they actually change or the metering changes?
    They should definitely not change (I've had the D40, D80, D200 and D90) and none of them changed on their own in manual mode.
  6. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    This may sound silly, but are you sure you're not in Program (P) mode and temporarily overriding the settings that it wants to use?
  7. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    Well, now it's holding the settings. I thing it may have had something to do with the AE lock.
    Thanks, guys,
    Jon
  8. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    That's what I was thinking. The D80 definitely holds its settings, even after power off/on.
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    There is no AE lock when in manual mode because there is no 'auto exposure'.
    There is something missing here, you will need to give us more info and confirm the mode you are in.
  10. choudhrysaab
    choudhrysaab TPF Noob!
    Jul 11, 2009
    667
    Toronto, Ontario. Canada
    I've come across the same thing but yes in my case i was "P" (program) mode so after each shot it'd go back to f/4.
  11. Aye-non Oh-non Imus
    Aye-non Oh-non Imus TPF Noob!
    Nov 18, 2007
    516
    23
    I saw this question not to long ago. It didn't make any sense..... that is, until someone suggested to make sure you haven't set auto-bracketing.
  12. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    No, I was most definitely in Manual mode. I did - I believe - have bracketing applied at the time.
    But why should that change my settings? Suppose I want to take a series of bracketed shots for HDR with the same settings?
    Jon
