Question about Nikon 50mm AF F1.4D lens (purchasing)
Discussion in 'Photography Beginners' Forum' started by dezignx, Jul 16, 2009.
  1. dezignx
    dezignx TPF Noob!
    Apr 25, 2009
    37
    Louisiana
    Hi,
    I am in the process of purchasing the 50mm lens for portraits...
    My question is....is there like different versions of the 50mm AF 1.4 lens?
    I came across an ad on craigslist and the man is selling Nikon 50mm AF F1.4D lens for $285 brand new....
    But, when I was looking on ebay I also see like G too. So, I am trying to see if there is a difference and if so, what version of the 50mm AF 1.4 lens will be better for portraits.
    Thanks
  2. dezignx
    dezignx TPF Noob!
    Apr 25, 2009
    37
    Louisiana
    hmmmm.....to my understanding the "G" is the newer lens model?
    (It's an AF-D lens, a G series, and it uses AF-S style focusing)
  3. Pure
    Pure TPF Noob!
    Oct 22, 2008
    420
    There are many varients of the 50mm, however...more specifically in your case....
    There are two main versions of the 50mm f1.4, the AF-D version, and the AF-S version.
    AF-D:
    -has aperture ring
    -uses screw-type focusing, in camera, not lens.
    -older style
    AF-S:
    -no aperture ring (coded "G" by nikon)
    -in-lens motor
    Both are awesome for portraits, I'd recommend the AF-D if you have a D50 or higher since AF speed won't matter with portraits.
  4. dezignx
    dezignx TPF Noob!
    Apr 25, 2009
    37
    Louisiana
    Thanx....I have a D90
  5. invisible
    invisible Been spending a lot of time on here!
    Mar 10, 2007
    5,213
    977
    Canada
    I have the 50 AF f1.4D and I can't be any happier with it. The newer version (1.4G) is much more expensive and the $$ difference is impossible to justify. Optically they are essentially the same lens –at least that's what the tests say.
    The regular price of the 1.4D is about $350, so $285 is a great deal. However, buying it off Craigslist you'd be forfeiting the warranty. Why don't you buy the gray-market option from Adorama instead? It's $320, so you'd be saving some money while still having the warranty (albeit honoured by Adorama, not Nikon directly).
    Just my 2 cents.
  6. DScience
    DScience No longer a newbie, moving up!
    Apr 12, 2009
    1,513
    122
    Denver, CO
    It's not that 'impossible' to justify. Yea they may both be 1.4, but you are the first person that I've seen to say they are 'identical' optically. The 1.4G is a whole new lens, built from the ground up. It's most definitely different enough to invest the extra hundred or so dollars. At 1.4 both lenses are quite smooth...however, take them to 2.8 or above and the 1.4G takes the lead with it's simply amazing sharpness and color.
    This is not to take away from the 1.4D...if you are on budget it's still an amazing lens.
  7. DScience
    Apr 12, 2009
    1,513
    122
    Denver, CO
    I also think the 1.4G isn't that much more expensive.
  8. invisible
    Mar 10, 2007
    5,213
    977
    Canada
    Before buying my lens I did quite a bit of research on both models. Like I said in my post, it's not me but the tests out there that say that they are optically on the same league. Right now the only test that comes to mind with these results are those of Photozone.
    When I said "it's impossible to justify", it was just my opinion of course.
  9. dezignx
    dezignx TPF Noob!
    Apr 25, 2009
    37
    Louisiana
    Thanx....I am weighing the options once again but I don't think the G is that much more expensive...maybe $100 more guessing.....but whichever version I will try to buy it new or something with a warranty
  10. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,224
    253
    Los Angeles
    Thom Hogan's opinion is the D version is no longer relevant now that that G is here.
    50mm f/1.4G AF-S Lens Review by Thom Hogan
