Question about Panaromas
Discussion in 'Beyond the Basics' started by cal_gundert05, Nov 1, 2006.
  1. cal_gundert05
    cal_gundert05 TPF Noob!
    Sep 27, 2006
    387
    I know you can create a panorama by setting up your tripod, taking a pic, rotating the camera so you have some image overlay, taking another shot, etc and them stitching all the shots together.
    But can you also take a "panorama-type" shot by taking multiple shots "head-on" while moving sideways along a path parallel to what you're shooting (like a landscape)?
    For example:
    -----HERE'S THE LANDSCAPE-----
    ==YOU MOVE ALONG HERE===
    Each ' represents your line of site for 1 shot
    Does that make sense? Would this look weird?
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    Assembling them will be a problem because the perspective will change as you move. The idea of assembling shots from a single perspective is that they will match at the point where they are attached to each other.
  3. cal_gundert05
    Sep 27, 2006
    387
    I think I know what you mean, but what if the shots were taken so close together that the change in perspective was negligible? That would take A LOT of shots, though.
  4. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    If you keep the camera level and move it so that the side edge of one frame is exactly the same as the adjacent side edge of the next frame, there should be no problem.
  5. fmw
    Sep 30, 2006
    3,656
    471
    No, the problem is at the joint where you assemble the images. You need to overlap a little. If the perspective (angle) is not identical, the overlapped section will be visible because you are shooting the two different shots from two different places. I would recommend shooting them from the same place. As soon as you move the camera (as opposed to swinging it on a single axis), you introduce a lot of variables. I don't think it can be done without a special track unit such as they use to shoot movies.
    My favorite tripod has a ball head because it is so fast to adjust. I don't think an assembled panorama can be done with a ball head either. It would have to be done with a head that has separate tilt and pan controls.
  6. fmw
    Sep 30, 2006
    3,656
    471
    Sure, but this is next to impossible to do.
  7. Mohain
    Mohain TPF Noob!
    Dec 29, 2005
    1,863
    11
    London, England.
    I've seen someone do this with decent results. It wasn't perfect but it was 'good enough'. I think it was handheld too. Make sure you overlap by about a 3rd and you should be OK. I'll see if I can find a link.
  8. Illah
    Illah TPF Noob!
    Jun 29, 2006
    110
    San Francisco
    The only way the walkabout method could work well is if you were shooting pretty long, any type of wide angle would suffer from the perspective issues fmw pointed out. Early in film school we actually had a similar experiment and fmw is right that the edges won't match.
    If you want to do it I'd recommend LOTS of overlap, so basically you'd only be using the middle 20% or so of the frame, then stiching those tiny chunks together. It's be really tough though - you'd need a path that's not only perpendicular but nearly perfectly level and in the middle of the subject (i.e. no low looking up at a building or high looking down - the perspective issues would be magnified quite a bit).
    --Illah
  9. W.Smith
    W.Smith TPF Noob!
    Oct 11, 2006
    440
    The more wide-angle the shots, the less "they will match at the point where they are attached to each other".
    Panorama's from a single perspective are less distorted if assembled from (as many as possible) overlapping tele shots.
