Question about programmed auto mode?
Discussion in 'Photography Beginners' Forum' started by Jimmy The Bat, Feb 27, 2010.
  1. Jimmy The Bat
    Jimmy The Bat TPF Noob!
    Aug 30, 2008
    55
    Massachusetts
    I just bought a new d90 last weekend, and in flexible program mode you can select different combinations of shutter speed/aperture. The manual says to rotate the main command dial until the flexible program icon appears in the control panel,then turn the dial to the right for large aperture/fast shutter speeds or to the left for small aperture/slow shutter speeds. I can get the icon to appear, but cant select different combos. I turned the command dial in each direction but it doesent move from the cameras setting. Am I missing something or doing something wrong? Any help would be much appreciated!
  2. Jimmy The Bat
    Aug 30, 2008
    55
    Massachusetts
    Please anyone?
  3. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,765
    13,477
    USA
    Are you using the main command dial, which is what Nikon calls the back or "thumb" wheel???
    Will it not allow you to select any different combinations of apertures? I was thinking maybe indoors, it would not allow you to select any faster shutter speeds because the lens was at its maximum aperture, and that perhaps you could select slower shutter speeds and smaller apertures, like f/8 at 1/3 second or something like that.
  4. Jimmy The Bat
    Aug 30, 2008
    55
    Massachusetts
    yes I am using the main command dial, and it will not change aperture or shutter speed. I was doing this in the house last night so the aperture was opened up, but I should still be able to slow down the shutter speed. I'll try it again today outside. Thanks for the reply.
nikon d90 programmed auto vs auto
programed auto
programmed auto
programmed auto with flexible program
programmed mode
progtammed auto
what is programed auto
what is programmed auto
whats programmed auto
