Question about SB900 off camera
Discussion in 'Photography Beginners' Forum' started by arkuro, Sep 7, 2010.
  1. arkuro
    arkuro TPF Noob!
    Jan 31, 2009
    64
    India/Saudi
    I was thinking of buying a nikon speedlight SB900. I havenot bought it yet and was just researching what all i can do with it. On one of the links I read that when u r firing SB900 off camera (wireless)... the inbuilt flash on the camera also fires. I have a D90
    1)so I am confused that if the flash on the camera will fire wont it ruin the exposure or am I wrong in understanding this?
    2)Another thing is how can u prevent from firing this inbuilt flash while using SB900 in off camera mode.
    3) If we can not prevent from firing this flash how can we avoid affecting the exposure?
  2. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    The CLS system requires the built-in flash to send a pre-flash to fire the SB900. This occurs almost instantaneously and cannot be seen by the naked eye. You can set the built-in to (--) via the menus, which supposedly does not affect the scene. For the most part, this is true.... for the most part. Read your manuals on the setup, both camera and flash manuals.
    However, at close range, with reflective subjects, this just doesn't hold water. See this link.
    http://www.thephotoforum.com/forum/...7323-using-sb-600-wirelessly.html#post1943300
    The other issue with CLS is the IR firing. While indoors this is usually a non-issue or can be circumvented by bouncing the pre-flash, outdoors in bright sunlight, you may have firing problems (receiver sensing the pre-flash).
    CLS is a great way to off-camera flash, but it's not the bees knees.
  3. arkuro
    arkuro TPF Noob!
    Jan 31, 2009
    64
    India/Saudi
    Thanks a lot.. so no way to stop that flash..will figure out a way to block it somehow though :)
  4. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    Kundalini pretty much hit it.
    Another disadvantage to CLS... forget about using it in your current configuration if you attempt doing portrait work. 90% of the time, the pre-flashes will cause your subject to blink....... just as the main flash(es) are going off.
  5. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    The only other options (that I can think of right now) are to use an SB800, SB900 or SU800 as the master (Commander) mounted on the hotshoe and triggering another optical slave flash unit off camera.
  6. arkuro
    arkuro TPF Noob!
    Jan 31, 2009
    64
    India/Saudi
    reading the answers is discouraging me to buy a speedlight.. (one I mean) :(... is it really that bad? :(
  7. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    Nope... buy a radio trigger & learn manual.
  8. PenguinPhotoWrx
    PenguinPhotoWrx TPF Noob!
    Aug 19, 2010
    100
    Eatontown, NJ
    I was wondering about this myself since I just got a D5000 but haven't bought into flash units yet.
    Just doing a little research, and speculation on my part, are there not 3rd party cables that attach to the hotshoe on the camera but allow you to remote the Speedlight? This fools the camera into thinking the flash is on-camera (thus disabling the built-in flash), yet still allowing you to remote the flash.
    Or am I misunderstanding how this works?
  9. meccalli
    meccalli TPF Noob!
    Jun 12, 2010
    70
    Trinidad
    Just get ebay triggers people!!! They solve everything unless you like automated stuff .
  10. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    Yes, there are, but they are typically very short. You can run a PC cord, which can be had in large lengths, but all they do is trigger the flash... not allow CLS control.
  11. mwcfarms
    mwcfarms No longer a newbie, moving up!
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    The SB600 manual sucks monkey nuts too. So if anyone has a better write up on controlling the damn flash I would ever be so grateful.
  12. PenguinPhotoWrx
    Aug 19, 2010
    100
    Eatontown, NJ
    What's an "ebay trigger?" eBay now makes lighting equipment?
cowboy studio npt-04 4 with nikon sb 900
cowboy studio remote how to use with sb900 on nikon
cowboy studio trigger with nikon sb-900
how to set up sb900
nikon d90 sb900 off camera stop built in flash firing
npt 04 with nikon sb 900
npt-04 4 channel wireless trigger and sb900
npt04 with nikon d90 and sb900
off camera sb900
trigger sb-900 off camera d90
