Question about step up rings...
Discussion in 'Photography Beginners' Forum' started by DannyB, Sep 25, 2008.
  1. DannyB
    DannyB TPF Noob!
    Aug 13, 2008
    109
    NC
    Is there any adverse effect in having too large a step, say 52mm to 58mm?
    I am going to order a 50mm 1.8D from BH in the next couple of minutes and I was wondering about filters. I plan on buying a 52mm UV protector with the lens but also wondering about the step up. Thanks!!
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    52 -> 58mm won't be a problem. Generally going larger is fine, but there comes a point when the "ledge" that the larger filter makes on the end of your lens becomes a hazard. I wouldn't go say, 52 -> 67 for instance.
  3. DannyB
    DannyB TPF Noob!
    Aug 13, 2008
    109
    NC
    Nice, sounds good and thanks for the reply! I was wondering about getting some glare/flare from going too big but a hood can solve that issue. Which brings up another question...A cheap rubber hood fit for a 58mm would work fine for what i need right or should I look for something else?
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    If you have other lenses that have a larger filter diameter, I would certainly suggest a step up ring for the 50mm. If you are going to get a UV filter, you might as well get a bigger one, also, buy a larger lens cap. Then you can leave the step up ring on the lens at all times.
  5. DannyB
    DannyB TPF Noob!
    Aug 13, 2008
    109
    NC
    I went ahead and ordered the rings with the lens :)
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Probably too late now, but this is the lens hood for your Nikkor 50mm f/1.8.
    Congrats, btw
  7. DannyB
    DannyB TPF Noob!
    Aug 13, 2008
    109
    NC
    Thanks for the link :) But if I am using a 52-58 step up ring and filters, wouldnt I need a hood to fit the 58mm?
  8. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    No, in that case a lens hood would not work with the step up ring in place, I don't think, at least not properly. However, if you are not using the step up ring, the hood will work on your 50mm lens. If you're buying the 52mm UV filter for the 50mm lens, might as well get the hood for $15. Just my 2ยข.
    Just out of curiosity, you DO have a lens with a 58mm filter ring, yes?
  9. DannyB
    DannyB TPF Noob!
    Aug 13, 2008
    109
    NC
    I already have lenses of 55mm and 58mm. I'll pick up a hood as well, can't hurt to have it for the price.
