Question About Stroboframe Camera Flip and a D300
Discussion in 'Photography Equipment & Products' started by Pugs, Jul 24, 2009.
  1. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    Hello,
    For my sister's wedding, she's hired a real photographer for the actual wedding and reception. For the rehearsal dinner (beach barbecue, really) she's asked if I would do informal pics.
    For my cousin's wedding a few months ago, I came to HATE the weird shadows from the SB-900 mounted directly to the camera when I went vertical with it.
    With that history, I'm looking at the Stroboframe Camera Flip bracket as it is the least expensive camera flip model I've found and it allows for my preferred vertical orientation with my right hand and shutter release on top rather than on the bottom.
    The problem is that I've read two reviews that say the D300 is too large for the frame. One of those reviews mentioned a mod being done to the bracket to make it fit, but doesn't elaborate on what the mod is.
    Does anyone have any experience with this combination of a D300 with the Stroboframe Camera Flip bracket? If so, can you provide insight into the size issue and/or the mod in question?
    I'm also open to other low-priced alternatives. I stress low-priced, because event photography is NOT my thing and I'm only doing this as a favor to my sister so any flash bracket I buy will be used only sparingly.
    Thanks in advance!
  2. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    I have that bracket adn cannot use it with my 40D if I put on the battery grip. If that gives you any size comparison, I hope it helps. Also, my nikon friends had the same issue with their D90 and D300. It looks like the combination of a battery grip and the off camera flash cord makes it too high for the capera to rotate without hitting the side of the frame.
    I wound up getting the Cusstom Brackets folding T bracket. It works pretty well and compresses to small space in my bag.
  3. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    Oh! But your friends were able to use it with the D300 without the battery grip?
    Thank you for the reply!
  4. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    No. They had the same problem. That bracket is made for non battery grip cameras.
  5. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    Right. I meant were they able to use it if they removed the battery grip from the D300.
    I really appreciate the feedback. Thank you!
  6. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    OH. I will ask him to be sure, but I know the D90 was able to use it.
  7. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    I am thinking it will not work. I saw this quote on Amazon's feedback for the bracket.
    " I now have a Nikon D300 which is a larger camera and the bracket does not fit. I can force it but who wants to chance... "
  8. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    Get a better bracket and sell it after.
  9. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    Fair enough, Keith! That option is now on the list. The question will be ready-cash and my wife's approval.
  10. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    You know. I would highly suggest just making one of these. I did not believe it at first, but it works perfectly and costs $3 or so to make with one trip to Wal-Mart. I used it recently and it really worked well. No red eye, and beautiful soft light.
    DIY Reflector-Diffuser
    PS. I used spray adhesive instead of sewing it.
    Also, I am heading out for a photo shoot tonight. I am doing some advertising shots for a local bar. I will be using this for a lot of the shots and off camera flashes/umbrellas for the bigger shots. Just to let you know I stand behind it. :)
  11. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    That doesn't address the situation where the speedlight is hanging off the side of the camera when it is held in portrait orientation, whereas a flash bracket does, which is what the OP is looking at.
  12. CxThree
    CxThree TPF Noob!
    Feb 25, 2009
    505
    Yes it does. Just attach it in the short end of your speed light. Whe you go portrait/vertical, roate your flash up toward the ceiling. This thing is 12 inches tall. It still puts your light source higher than your lens and results in no red eye and it pushes the shadows down behind the subject.
    Here's the commercial version of it. Check out their video.
    Lite-Scoop Flash Reflector
    Also, look at threads in this forum. There is good info on exactly what you are trying to do. Read the discussion in this one. http://www.thephotoforum.com/forum/...news-reviews/170334-bigger-flip-released.html
