Question about the D40 and it exposure meter
Discussion in 'Photography Beginners' Forum' started by pauliec, Jan 19, 2009.
  1. pauliec
    pauliec TPF Noob!
    Jan 18, 2009
    88
    New Jersey
    I am still playing around with my first SLR and getting the hang of it, and have found this guide to be immensely helpful: Nikon D40 User's Guide
    However, one question -- the author states that he has to compensate for the D40's exposure meter, because it is notoriously faulty:
    Does anyone else familiar with the D40 or D80 find this to be true? Honestly I am not familiar nor proficient enough to recognize how far off the metering firmware is in regards to the photos, so I was wondering if I should get a second opinion before I take his advice and set it to -0.7. In other words, to my untrained eye I don't know how much of a difference it will make. Thanks.
  2. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    The correct exposure setting for the meter is subjective, as is the author's opinion.
    Digital doesn't like overexposed highlights, the information is clamped instead of falling off smoothly like film. This is why many prefer to underexpose digital slightly. doing this will increase the amount of noise in the dark areas of the photograph, so there is a tradeoff.
  3. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Check the Histogram.... Or if you know someone that has a light meter, check it. I have never found there to be a descepency, D40,D50,D70,or D300...
  4. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    My D40 exposes perfectly, except with flash, I keep +0.7 flash compensation on all the time.
  5. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    I bet you don't have your camera or flash set right. Probably don't have the aperture set quite right...
  6. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    If I set everything manually then obviously I can get the exposure right, but in Auto, P, A, and S modes the camera/flash underexposes, this applies to both built-in flash and my SB-400.
    In any of those four modes, with TTL flash metering set, the exposure should be perfect but it isn't.
  7. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    hmmm, this sounds weird. You should be able to set your aperture and that should set your flash exposure. The background will be determined by the shutter speed... I'm not sure what else would cause your under exposure.
  8. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    Is the entire image underexposed or just the subjet, or just the background?
  9. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    It's definitely weird, I figure it's just some small glitch in my camera. It doesn't worry me, I just leave the flash compensation permanently set.
  10. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    lol.
  11. MikeBcos
    MikeBcos TPF Noob!
    Nov 1, 2008
    548
    7
    St. Louis, Missouri
    Missed this, it's the entire image.
