Question to all Nikon D3100 owners :)!
Discussion in 'Nikon Cameras' started by 0ptics, Dec 5, 2011.
  1. 0ptics
    0ptics TPF Noob!
    Nov 8, 2011
    77
    WA
    Hello!
    So I recently received my Nikon D3100 and had a question about the battery; when I opened the package I grabbed the battery/charger and plugged it in, after about a day and a half of using it (taking random photos, playing around with functions) my battery was down to the last bar, and I used it until it reached the open where I wasn't able to use the LCD, only the Viewfinder. Then I looked online about the average battery life for the Nikon D3100, and on average it was 550 shots; I was just concerned that maybe my battery or camera was faulty? Using it just for a few shots/functions wouldn't seem like it would drain the battery so fast.
    Also the battery is: Nikon Lithium Ion Battery Pack En-EL14 7.4V 1030mAh 7.7 Wh
    Thanks
    -0ptics
  2. caughtmyeye
    caughtmyeye TPF Noob!
    Dec 1, 2011
    28
    UK
    Try charging it
  3. flatflip
    flatflip TPF Noob!
    Nov 20, 2010
    556
    10
    550 shots does not include learning the menus. Give it some time. Mine is new too. It went down to one bar after a couple days but has stayed there for a while now.
    Turn off Focus Assist Lamp and turn off View Image ( where it shows you the picture after every shot ). Make sure your "turn screen off" settings are low too.
    Hope you're off of "Auto" too. Of course the flash would drain the battery too.
  4. 0ptics
    0ptics TPF Noob!
    Nov 8, 2011
    77
    WA
    Ya I'll definitely change some settings to increase battery life, I was just worried that it was my battery or camera; wasn't exactly sure how long DSLR batteries last in general because this is my first DSLR.
    I just wanted to compare what other's battery life on their D3100 is like, eg. how many shots, use time, etc. before your Nikon D3100 drains out.
  5. flatflip
    flatflip TPF Noob!
    Nov 20, 2010
    556
    10
    Any luck? I got my D3100 right before Halloween. I finally charged the battery last night after about 190 shots. I was bummed that it still showed 1 of 3 bars but the message said shutter disabled for low battery. I missed a shot. I knew it was risky but I wanted to deplete the battery on the first full cycle ( for battery health).
    Sent from my iPhone using PhotoForum
  6. KmH
    Apr 9, 2009
    39,354
    5,307
    Iowa
    Doing that has no positive or negative effect on Li-ion batteries, but does with some other battery types.
  7. flatflip
    flatflip TPF Noob!
    Nov 20, 2010
    556
    10
    Well, I was trying. That's the only time I screw up.
  8. Abhi.Naik
    Abhi.Naik TPF Noob!
    Nov 27, 2011
    21
    Mumbai, India
    I didn't understand your question. I'm assuming you meant you used the battery as soon as you opened your box. In that case, it's normal because the battery doesn't come fully charged in the box. Mine ran out after a day, although I must actually have used it in all for an hour or so. I charged it for around two hours, and now it's proper.
  9. NateTheGreatDog
    NateTheGreatDog TPF Noob!
    Dec 10, 2011
    13
    Redlands CA
    the battery life isn't that long, but if you are using the LCD a lot or have the focus assist light on it drains rather quickly.
    i solved this by buying an extra battery :D but if you do buy one make sure its an original Nikon battery.
how long does it take to charge a nikon battery
how long does nikon battery last
how long to charge a nikon d3100 battery
how to charge a nikon d3100 without a charger
how to charge nikon d3100
how to charge nikon d3100 without charger
nikon d3100 battery charge time
nikon d3100 battery charging time
shutter release disabled recharge battery nikon
what kind of batteries does d3100 use
