Question to Nikon owners who shoot in RAW
Discussion in 'Photography Beginners' Forum' started by Vinny, Mar 27, 2010.
  1. Vinny
    Vinny TPF Noob!
    Mar 14, 2010
    667
    New Jersey
    I've read that Nikon uses a proprietary RAW process that needs its own software to pull the image out. I've also read that the standard software Nikon issues is not complete (?) and it's higher level software is (??).
    I don't plan on shooting RAW that often but hey if its there then it might be nice to play around with when I want to be creative.
    Can someone tell me if the standard is good enough.
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    I am sure you will get lots of view on this question, but i will tell you what i tell my students. Try the free software given to you by the camera maker and when you out grow it, if you do, then consider options.
    Capture NX2 is certainly contains more tools and "toys" to play with but if your not shooting raw enough to warrant the cost right now, download a trial version. You might try a dealer who sells the software as Nik also has a dvd that allows a trial version for 60 days. Online might be the same length of time, but i don't know .
    there is another piece of software developed by someone involved with the nikon products that you could also try, it is called toneup3 and cost about 20 dollars and uses the math from nikon for converting raw and they also have a trial period. I have no connection with them except the fact i tested out the software and found the fellow to be very helpful with his support.
    what other editing program do you all ready own, which may convert the RAW files?
    which camera are you using and just be sure the software supports that model.
    I believe picasa will do RAW at this time.
    "Good enough" is really up to individual standards , so that is why i am suggesting options.
  3. FemFugler
    FemFugler TPF Noob!
    Nov 12, 2009
    288
    Canada
  4. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    As mentioned, Picasa (free) will open the RAW files - but you loose a lot of the things you shoot RAW for (adjust exposure, white balance, etc).
  5. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    You can use any raw converter you want/feel comfortable and tweak the image to what you want it to be, however, an advantage of using Camera Manufacturer's native software, Capture NX2 in this case, is that it'll read you camera's settings.
    I shoot standard with sharpness at 5, saturation increased and custum WB. In anything other then Capture, it takes longer time to process RAW files to my liking. When shooting JPG, LR and PS do MORE then enough...
  6. --ares--
    --ares-- TPF Noob!
    Aug 17, 2009
    152
    Adobe has plugins for all NEF (nikon RAW) files. For me they work great and pretty easy to install. I can imagine that GIMP might have RAW abilities since it is open source, or has readily accessible plugins that can make it work.
  7. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Lightroom.
  8. outamyway
    outamyway TPF Noob!
    Mar 8, 2010
    30
    USA
    Lightroom is good.
    PS has Camera Raw that will open RAW files (Some newer cameras may require a plugin like my D300s RAW files won't open in PS3 apparently the plugin is good in PS4 though) I never needed a plugin for my RAW files from my D80 though even in PS3.
  9. mr sussex
    mr sussex TPF Noob!
    Mar 7, 2010
    17
    I use NX to convert the NEF to TIFF, this is because NX does a much better job on skintones than the Adobe RAW converter.
    I then work on the TIFFS in Photoshop.
    Bibble is also a well regarded RAW converter.
  10. KmH
    Apr 9, 2009
    39,491
    5,330
    Iowa
    Most camera makers have a proprietary RAW data format. Each camera maker usually produces a unique format for each camera model so if you upgrade your camera you also have to upgrade your RAW converter.
    Nikon's View NX, which comes with each camera, can display your RAW images. If need be you can go to Nikon's USA web site and down load View NX for free.
    Adobe has a free, universal RAW converter for "Digital Negatives": Adobe - Search: DNG
    I convert my Nikon .nef files using Adobe Photoshop's, Adobe Camera RAW (ACR).
.nef file photoscape not:photoshop
does photoscape handle nef
nef photoscape
nef plugin for photoscape
photoscape and nikon 5100 raw files
photoscape how to work with nef
photoscape nef
photoscape nef files
photoscape open .nef file
photoscape raw file
