Questions about shooting band pictures
Discussion in 'Photographic Discussions' started by R0TT3NBURIT0, Feb 9, 2008.
  1. R0TT3NBURIT0
    R0TT3NBURIT0 TPF Noob!
    Feb 5, 2008
    59
    FL
    Hi, I've just been shooting bands, and I havent quite gotten a photo as cool as this one.
    [​IMG]
    I've been wanting a photo like this one, mostly because of the light streak. I've had a lot of experience in photoshop, and ive blended one of my light streaks with a photo I liked, and it did something similar, but I want something that can help me get a photo with out putting in a lightstreak with photoshop. If you have any tips, suggestions for equipment reply please.
  2. Paparoksguitar
    Paparoksguitar TPF Noob!
    Nov 23, 2007
    175
    Forgive me if I'm wrong, However I'm pretty sure he used an exposure like 3 seconds or something, used flash to freeze the guitarist and then swiveled the camera around to get the light like that.
    I've never tried it though, only read it in magazines.
    Edit: I'm not positive though, someone should probably clarify.
  3. R0TT3NBURIT0
    Feb 5, 2008
    59
    FL
    Wow that is probably what he did, but i can't do light streaks with flash.... hmmmm... hat you just said made perfect sence, but do you think you can give me step by step instructions on how to do it. or find a online link that posted this?
    If you could spare sometime i would apreciate it :)
  4. Paparoksguitar
    Nov 23, 2007
    175
    Well i can't find a link to it on the web, but i found it in PC Photo magazine: the January - February edition I'll give you the instructions.
    This is what she said,"First i slowed the shutter speed. Using the flash i shot the picture, which froze the subject in the split second the flash went off. Then i rotated the camera streaking the lights across the image (the foreground is frozen by the flash at 1/1000 sec. while the background is recorded at 1/2 second)
    I don't know if that helps you. I would suggest just exposing it at 1 second. But you might wanna test it a bit. You can do this by just getting in a dark room semi-light get somebody moving in front of you with a bright like behind em, and take the shot..See what happens.
  5. R0TT3NBURIT0
    Feb 5, 2008
    59
    FL
    Thank you so much ill do it tonight. :)
  6. Paparoksguitar
    Nov 23, 2007
    175
    no problem :)
  7. DSLR noob
    DSLR noob TPF Noob!
    Feb 7, 2007
    1,527
    7
    Atlanta, GA
    meter your camera and flash for the subject (helps to have a flash that has settings) go into manual, slow the shutter speed a few stops, and take the picture while waving the camera. the flash should "freeze" the moment in bright light for your camera, and then the dark room that has no flash will add streaks from stray lights.
  8. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Bulb with flash, and shake the camera around.
  9. R0TT3NBURIT0
    Feb 5, 2008
    59
    FL
    Yea it worked. I did it to a wall, cause i had no one to test it. ill post it later today. i need to put it on photo bucket
  10. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Uhmm... Are you saying that you are not the owner of this photo? If that is true please link it or take it down.
    Shoot with your flash on slow or rear curtain sync. All cameras have it. It will take a lot of experimenting, but the effect is interesting.
    Love & Bass
  11. R0TT3NBURIT0
    Feb 5, 2008
    59
    FL
    Yes, its not mine, i don't want to take it down because it gives an example of what i'm looking for.
    and i got it already so you didn't have to tell me. thanks anyway
  12. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    I think what craig was pointing out is that it is against TPF policy to post a photo that is not owned by you. If you need to "show by example", then the appropriate action is to link it.
band photography
how to get light streak band photos
how to take photos with light streaks bands
