Questions about slide film.
Discussion in 'Beyond the Basics' started by Ghoste, Dec 28, 2004.
  1. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    Basically.. I don't understand it, how it works. If someone could explain to me or give me a sight about the difference between regular film and slide film this would be excellent. And maybe why you would, or why you wouldn't use it. Thanks :D
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    How to explain this simply?
    'Regular' film is negative film - that is colour and tonal values are reversed (light becomes dark, green becomes red etc)
    The film is then printed onto paper to give a positive image (everything is reversed again).
    In 'slide' (more properly 'transparency' or 'tranny') film the image comes out positive in the first place.
    This is done by developing, re-exposing and re-developing.
    That is, instead of producing a neg and then printing it in the D/R, the whole process is done during development.
    Tranny was used primarily in Pro photography that was intended to be reproduced in magazines - for a number of technical reasons.
    Because tranny is viewed by transmitted light (as opposed to reflected light with a print) the colours are richer, contrast better, and so on. A bit like looking at pictures on your PC monitor as opposed to prints.
    If you need to ask why you would use it then the rule of thumb is 'you don't need to use it'.
    Hope that helps. ;-)
  3. DIRT
    DIRT TPF Noob!
    Sep 27, 2004
    380
    5
    Long Beach CA.
    you can also use slides to make polaroid emulsion lifts using a slide printer if you want to get creative.
  4. Ghoste
    Ghoste TPF Noob!
    Dec 27, 2004
    552
    Yorba Linda, CA.
    But the slide film can just take the spot of regular 35mm? How do you load it?
  5. rmphoto
    rmphoto TPF Noob!
    Nov 25, 2004
    86
    vancouver canada
    load it like regular film
  6. PreludeX
    PreludeX TPF Noob!
    Nov 22, 2004
    681
    Nellis AFB, Las Vegas, NV
    yeah loads like regular film.. like stated. its processed way differently.. GO E-6 ya!
