Questions on chemical/developing steps
Discussion in 'The Darkroom' started by rob91, Mar 9, 2008.
  1. rob91
    rob91 TPF Noob!
    Nov 3, 2007
    708
    Just a couple things. The darkroom I use at school has a chemical I don't hear mentioned much, "Hypo Clearing Agent". After fixing I rinse for a couple minutes, then HCA about 1-2, then a 5 minute water rinse followed by photoflo. Is the HCA necessary?
    Also, one step I was taught was to start off with a water rinse (fill with same temp water, agitate for a minute) before putting the developer in. Does anyone else do this?
    I just wonder because these steps were taught for use with Kodak films. When I start going in with some fuji and ilford, as well as some expired Kodak Tmax I will be shooting, are such steps are necessary? I don't see them listed on the manufacturer's website, or many other developing sites for that matter.
  2. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    I believe you'd have to wash the film for a good half hour without it, so it basically saves water. A must for fiber based papers.
  3. nealjpage
    nealjpage multi format master in a film geek package
    Sep 16, 2005
    3,479
    Oregon
    I never use it myself for rinsing. After I fix, I rinse the film for 7 minutes in running water. Haven't had a problem yet. I could go to 10 minutes if I wanted, but, eh, I'm lazy.
  4. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    many years ago, a pre-wet was used as the films were much thicker.
    these days especially with 35mm and 120 film many feel it is not useful.
    with regard to hypo clear and film. again it is no longer necessary.
    With fiber papers yes, it will decrease the washing times.
    a very popular washing method for film is the ilford 5-10-15 method which we have been using to conserve water.
    you fill the tank with water and agitate 5 full inversion, dump, re-fill, agitate 10 times, dump and re-fill agaitate 20 times. followed with a photo-flow in distilled water.
  5. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    I do use it, and I do a pre-soak as well. Why? Hell if I know. Not my chemicals. I was taught this way.
  6. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    I'd stick with that to be on the safe side. It's a small step. Any residual fixer remaining will most likely degrade the negative in time.
  7. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    The old 'To presoak or not to presoak' question. I do for one minute. Let's the water get into the emulsion to promote more even developing, brings the film, the tank and the reels up to processing temperature before adding developer, supposed to make the film more resistant to air bubbles during developing. Do it or don't, honestly makes no difference one way or the other.
  8. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    25,572
    2,193
    In the mental ward of this forum
    Keep in mind a pre-soak is not advised for all films. If you check the Ilford website, they actually recommend against a pre soak, as this can lead to uneven development - exactly what you are trying to avoid!
    I believe many of us get taught the old school methods and some of them simply no longer apply with modern films.
    I also agree with Ann about the water-saving final rinse steps. I do this all the time now. I believe this also came from Ilford labs. It saves a lot of water and is apparently a more effective method of washing.
  9. christopher walrath
    Mar 19, 2008
    1,265
    24
    I do like ann's suggestion on final rinsing. I'm gonna see how it goes with TMX, Noepan 400 and Efke 25 with HC110, K's Ind Stop and Kodafix. Would save time and a lot of water. Course I run it at only a trickle but still twenty minutes adds up (no hypo).
chemical developing
chemistry steps of developing in a dark room
do chemistry step to develop photo
steps and chemical in a dark room
water saving rinse for kodak film
