Quick Help
Discussion in 'Photography Beginners' Forum' started by aammoore, Jul 7, 2008.
  1. aammoore
    aammoore TPF Noob!
    May 8, 2007
    130
    I have a picture that I am trying to print as an 8x10 but the image is too wide and I cannot fit the entire image into an 8x10. How do I fix the image in Photoshop to get the full image onto the print?
  2. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    You go under image, and image size on the top. the under the dimensions switch it to inches and then set it to 8X10. hope this helps!
  3. aammoore
    aammoore TPF Noob!
    May 8, 2007
    130
    I've done that..wouldn't let me change it
  4. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Huh, thats weir, you can post it on here and I can try to change it if you want, it only takes a second
  5. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    I'll bet that the problem is that the aspect ratio of your image, does not match the 8x10 ratio. The standard photo sizes are all different.
    In that case, you need to crop the image to the correct ratio. In photoshop, click the crop tool and then at the top of the screen there should be a couple fields where you can set the size/ratio. You can enter 8x10 or choose it from a list of presets.
  6. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    Ya that could also be it. good thinking I didn't even think of that.
  7. aammoore
    aammoore TPF Noob!
    May 8, 2007
    130
    how do I upload the image on here...its still not working
  8. aammoore
    aammoore TPF Noob!
    May 8, 2007
    130
    Tried the cropping as well the whole image wouldn't fit.
  9. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    http://www.thephotoforum.com/forum/showthread.php?t=73415
    Then you have to cut off some of the image to make it fit...that's what cropping is.
  10. aammoore
    aammoore TPF Noob!
    May 8, 2007
    130
    Um yeah..but I can't cut off people..lol
  11. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    That's why I try to compose shots with some room around the subjects...so that I can crop to different ratios if needed. :er: ;)
  12. aammoore
    aammoore TPF Noob!
    May 8, 2007
    130
