Quick PS question
Discussion in 'Beyond the Basics' started by danalec99, Aug 28, 2004.
  1. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    I created a new layer. This is how I did it:
    -Layer/New/Layer
    Gave it a Name, No Color, Normal Mode, unchecked the 'Group with Previous Layer' and said OK.
    -Then I did Image/Adjust/Gradient Map, but the message that I got was
    "Could not complete the Gradient Map command because the active layer is empty"
    Whats the story here? How do I make changes on a new layer?
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Use a gradient map adjustment layer. It's in a menu that you access from the bottom of the layers palette. Much easier.
    If you were doing ti the way you did, you would just need to fill the layer in with a color first. White or black would do.
  3. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Thanks D.Matt :)
  4. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    -When you create a new layer, do you 'Group with Previous Layer'?
    -And, what is the purpose of layering? How do we recollect the history?
