photoman said:I dont beleive you could because you are going into the range of distortion for the 28mm lens (objects seem bigger closer up and things farther away are very close (exaggerates depth)). 50mm lens is more like what you see in life (human eye). If you go telephoto you would compress the background and make everything seem really close together.
The simple answer is no you cannot with that small of a mm. :shock:
Different mm lenses produce different effects, that is why most people tell you to stick with a 50mm lens or a fixed focal length, because you cannot just use your zoom to capture the same picuture in the distance if you just zoomed in, rather than actually getting closer with a 50mm lens.
Hope that helped
