Quick question
Discussion in 'Photography Beginners' Forum' started by R6_Dude, Feb 12, 2010.
  1. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    When shooting somebody blowing out a birthday cake candle, should I shoot in Av or Tv (shutter priority). I took a couple last week in burst mode and 1 out of 7 or 8 came out looking decent.
    Is the general rule for anything having movement to shoot in Tv?
  2. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    I would shoot it in (manual) but AV because you are shooting a portrait, but have you got a fast lens,
  3. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    That was probably the problem I was shooting with my kit lens at f3.5. If I had my 50mm f1.8 it probably would have came out better right?
  4. PackingMyBags
    PackingMyBags TPF Noob!
    Jul 20, 2008
    136
    NorCal
    Bump up your ISO if you need to, but i would go AV and set your aperture to 3.5. Your 50mm is a much faster lens, so i would use that if your lighting is low.
  5. CoRNDoG R6
    CoRNDoG R6 TPF Noob!
    Dec 25, 2009
    137
    California
    Yeah, what they said! :D Use your 50mm instead of your kit lens in low light conditions. If your stuck with your kit lens only, bump up the iso and balance clarity with the noise produced.
  6. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    I'd go manual mode myself...
  7. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    A lot, obvious depends on what you want to get...
    Some recommendations that are out there are for portraits, landscapes and producs to use Aperture Priority and for action sports shutter priority.
    Personally, I shoot manual but on rare occasion when need shallow dof and don't want to think and calculate exposure will switch to aperture.
  8. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    What's your end goal? Are you wanting to see motion in the flame? Are you wanting to freeze the action?
  9. R6_Dude
    R6_Dude TPF Noob!
    Jan 14, 2010
    151
    SoCal
    Freeze of action. For those that would shoot in M, what would you set your shutter/apperture too in a low light setting?
  10. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    That depends on the light. :greenpbl:
  11. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    What body do you have again? I know when I bumped up the ISO on my XTI it was as noisy as a freight train however my 1/5 D's are very smooth so there are a lot of factors... and what lens? I would use the Fitty in this case...
  12. Dominantly
    Dominantly TPF Noob!
    Jul 30, 2009
    3,032
    166
    San Diego, CA (RB)
    A good question was in regards to your intention with the shot.
    IF you goal is to stop action, then you'll want to be in control of what stops action, and that would be your shutter. If you are comfortable with Manual, I would shoot it that way, it will keep your shots consistent within the same lighting.
    If you shoot Tv, you may have a slight difference in your photos as your camera adjusts per changing lighting and scenes. This can throw off your intended exposure a bit.
    So, pick a motion stopping shutter speed:
    (from my thread in my sig)
    Shutter speeds and what they do:
    1/4000 to 1/2000.......... Stop a Hummingbirds wings
    1/1000 to 1/500............ Freeze a human running and most athletes
    1/250 to 1/60............... Stop most daily movement and handheld blur safe
    1/30 to 1/8.................. Blur motion (camera should be on a tripod)
    1/2 to long time............ Dark scenes, night time, etc (tripod only)
    Once you have your shutter, you need to set up everything around it. You can keep your iso relatively low to minimize noise and then open your aperture up (shallow DOF might be not wanted though) or you can turn it up and keep a good aperture (maybe f/8).
    It's all up to what you want your shot to look like. I would agree your 50mm would be most useful if you don't mind shooting at f/1.8.
