Rapid-Omega problem
Discussion in 'Medium Format & Large Format' started by montresor, Mar 11, 2007.
  1. montresor
    montresor TPF Noob!
    Aug 22, 2005
    289
    Cleveland Hts., Ohio
    Tried the 180mm lens on the Rapid-Omega 200 -- everything looked great in the rangefinder, but the negs came up way fuzzy! I assume that I need to make some kind of RF adjustment for the long lens. Just for the record, focus is fine for the 90mm and the 58mm (though maybe the DOF at 58mm is deceiving). Anyone have experience with this who can advise?
  2. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    How far away were you trying to focus? It has been a while since I have used a RO or KO but, under 14 feet or so the 180 lens will not focus well at all, not to mention it can be a difficult lens for this camera to focus with the range finder. Another problem could be the pin on the lens that registers with the range finder and focusing device could be out of alignment somehow, not 100% sure my memory remembers how it works though.
  3. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,778
    50
    Ahwatukee, AZ
    ^^Excellent!
    I would also check the film pressure plate on the KO back, it's known to have a weak spring. Have you tried to shoot at smaller apertures with that 180mm? If the pics come out sharper at the smaller apertures (11,16,22) then it might be the film pressure plate. Just a thought...
  4. montresor
    montresor TPF Noob!
    Aug 22, 2005
    289
    I checked the pressure plate springs and they seem to be good. I wonder if the pin is an issue, it gave me more than a bit of trouble when mounting it. That sounds like it would be a tough and expensive fix, though, and I'm hoping it was a matter of operator error. I was treating it like a 300mm zoom on a 35mm camera. The distance might also be an issue, I was using it on the street, handheld, and focusing fairly close, about 15-20 feet away. Will re-try with it battened down on a tripod and focused far away. Thanks for the help!
rapid omega 180 mm lens for portrait
what viewfinder do you used for your koni omega 58mm lens
