RAW images
Discussion in 'Photography Beginners' Forum' started by bazza, Jan 9, 2007.
  1. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    This might be a silly question but does anybody know the best way to aquire my raw images from my 350d to my pc.. Also what program is the best for altering the photo..
    Its the first time I have used raw and i'm a bit confused..
    Any help would be great.. ta..
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The best way to acquire them is with a usb 2.0 card reader. You should have Digital Photo Professional which came with the camera. This program is designed for processing your RAW files. It's decent, and I'd start with that. You can also check out Raw Shooter Essentials. There are lots of programs, incuding Adobe photoshop CS and CS2. Once you become more comfortable with RAW, you can decide on another program if need be.
  3. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Cheers Matt, i've recently purchased a laptop and given away my old card reader as i have got one built in. On closer inspection it doesn't support a compact flash card.
    Do you know of another way??
    Ta.
  4. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Does your laptop have a pcmcia slot? You can get an adapter for that. Also, card readers are plug into a USB port. I'm sure your laptop has a few USB ports.
  5. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Don't know what a pcmcia slot is but i think i'll get an external usb2 card reader.
    Are shots took in raw a lot better than jpegs at high resolution or is it just another way to edit them?
    Can you get the same result in photoshop??
  6. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    HERE is an article titled 'Why RAW?', it should give you an insight.
    Basically, a RAW file is the image data right from the camera. If you record your images in JPEG, the camera applies it's own editing and then compresses the file...so you loose data. For most people, it makes sense that you don't want to loose data, at least not until you compress a copy of the file for web viewing.
  7. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Thanks mike, Bit over my head but it does explain a lot.
    Just got to retrieve them from my camera.
    Thanks again.
  8. RacePhoto
    RacePhoto TPF Noob!
    Dec 29, 2006
    562
    5
    Wisconsin
    PCMCIA is the two slots on the side of the laptop. You can plug in network cards, modems, and in this case Card Readers. The reason I like the PCMCIA slot card reader is that it's small and inexpensive. Last I looked $19 at Circuit City so I went across the street to Best Buy and found one for $11.
    Your external USB reader will cost a little more but you can get multi-card readers that will read CF, MMC/SD, xD and others. They will also plug into any USB on a desktop. So if you are going to potentially use a desktop, get a multi-card USB card reader.
    I just prefer the little card reader because it fits in the camera bag without taking up much space, no cables. I carry the reader with the camera, not the computer, because I figure if I have the camera, I can use any computer, not the one sitting at home? ;)
    I have all of the above and a printer that reads CF cards as well.
    Silly me, I have to add this. Your camera has USB output, all you need is a USB cable with the right ends on it. Should have come with the camera. Tip, if you go to some places like Radio Shack, the cable costs more than a card reader!
  9. bazza
    bazza TPF Noob!
    May 22, 2006
    261
    Wirral, UK.
    Thanks for that, it has a pcmcia slot i'll try and find one of those..
    I've tried using the usb connection via my camera but using raw it always says no files.. any suggestions??
  10. Wolff
    Wolff TPF Noob!
    Oct 30, 2006
    115
    Montana
    You need the right program to get the raw photos using a USB cable. The program that came with the camera should work fine for this but, in my experience, you have to open the pictures through the program, not drag the file to the program.
  11. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    You should be able to just open the card/reader as a new drive on your computer and drag the files over . I've heard that with some set-ups, you need to download an update for windows (assuming your using Windows) which will allow it to recognize your RAW files.
  12. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Don't bother trying to connect the camera via usb, unless you are shooting tethered. To transfer images, it's a waste of battery. You can take the CF card out and shut the camera off. The PCMCIA is your best bet, short of a usb card reader. The advantage of a usb card reader however is, you can use it on ANY computer, not just a laptop.
