RAW question.....
Discussion in 'Photography Beginners' Forum' started by dEARlEADER, Apr 24, 2008.
  1. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    When I import RAW (NEF) files.... are my camera settings completely unassociated with it??
    In other words.... is there any point whatsoever in trying to get the camera settings right (white balance etc.) when shooting RAW? or will they all just be lost on import....
    I'd like to shoot RAW.... but I don't want to have to edit every single picture I take... I would like to use my desired camera features (for sharpening, whitebalance, saturation etc.)... and only undo them if I mess up the shot...
    thanks
    oh... and another thing... what is better RAW or JPEG.... hahahahha:lmao:
    **THIS IS NOT A RAW VS. JPEG THREAD**
  2. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    You can shoot in raw and just convert to jpg without making any changes and from what I'm seeing it will have all the settings.
  3. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,665
    22
    California, USA
    No, hes asking if he makes WB adjustments on the camera while in RAW will they make any difference? Will the adjustments be lost on import?
  4. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    If he makes WB adjustments on the camera while in RAW will they make any difference? it will take the shot the way he has the shot setup. RAW is still the image created from the settings used. Everything you do in RAW will be kept when you take the shot as if you were shooting in jpg(trying not to start debate)
    The only difference between settings used in RAW and settings used in JPG are the scientific differences between the two types of images and the fact that the image is not processed by the camera in RAW
    Similar to black n white vs greyscale. this might not be the best comparison
  5. BoblyBill
    BoblyBill TPF Noob!
    Oct 30, 2006
    2,860
    36
    in the eye of a tornado
    :popcorn:
  6. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    :popcorn: LMAO!!!
    I'm trying not to start a debate either because I think that other one is still going.
  7. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    Yes, your settings will still be associated with the RAW file as your 'as shot' settings.
  8. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    I've read on this forum of people complaining about their RAW files are imported without much colour and/or sharpness....
    I'm just wondering how this is possible if the RAW file starts off by using the camera's settings as adjusted by the user.....
  9. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    I'm not claiming any one is better than the other and even noticeably different or not. What I use as my reason for using relates to what my company does.
    If we have to OCR(optical character recognition) a document we will scan it in 300 DPI because more pixels are used to aid in the computer recognizing the letters better. You can scan in 200 DPI and OCR it but you will not have the same OCR confidence.
    Now that I lost you. I'd rather look scientifically at the facts. I'm not saying someone can tell that a shot of mine is from a RAW originally or a JPG originally but because I'm relying on my computer to process the image and not the camera
  10. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    I think it differs...depending on the software that you are using...and the settings that we are talking about.
    WB, for example, will usually be adjusted to the 'As shot' value. The sharpness, saturation, sharpness etc. settings usually aren't applied to the image. I'm not sure if the RAW files reads the in-camera settings for those or not. With the RAW programs that I've used, you can set a default profile for your camera...so you can have those things pre-set...but either way, you can still adjust those things in the RAW software.
  11. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    Okay.... does anyone know of any software that uses ALL of the cameras settings when importing a RAW file?
    I want to be able to set my camera w.b. to SHADE, Sharpness +1, Vivid Colour saturation, D-Lighting active.... and have ALL of these settings come through on the RAW import.... then... let's say my technique was wrong... I want to undo all of those in camera settings and start from scratch... how would I do this?
  12. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    How about this?
    One of the good things about good RAW software (Lightroom etc.)...is that you can apply settings groups of images.
    So in your scenario, you could open Lightroom and then globally apply "SHADE, Sharpness +1, Vivid Colour saturation" to all the photos, with only a couple clicks.
    If you don't think those are the right settings, the change it and apply that to all the images...or just to the ones that you want.
    The point is that with good software, it is so very easy to set & change these things...that doing it in camera seems like a waste of time & effort.
    I really didn't like shooting in RAW until I got RAW Shooter Essentials (sort a precursor to Lightroom). Now, it's very easy and more enjoyable.
