Raw vs. JPEG
Discussion in 'Photography Beginners' Forum' started by Kawi_T, Dec 13, 2007.
  1. Kawi_T
    Kawi_T TPF Noob!
    Nov 19, 2007
    173
    Chicago suburbs
    I've had my camera set on JPEG but read on here that most people set it on raw. Whats the advantages/disadvantages? Should I switch?
  2. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    Advantages - Better control over boo-boos done while you were out in the field (bad exposure control, improper white-balance set, etc.)
    Disadvantages - File size. Drains battery faster. Cannot direct print a RAW file, must open with first or third party software.
    Prepare to be told to "learn how to search, noob!".
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    RAW has a substantial increase in information 8-bit vs. 12-bit. WB doesn't matter, and images are generally more detailed.
    And when doing extensive post production, there's no jpeg compression that you need to worry about.
  4. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    It's kinda like working in TIFF in photoshop. Doesn't compress anything, has greater bit depth, and huge file size.
    It does allow you to change yoru white balance with one click...as well as making it easier to adjust exposure.
    If you're happy with your pictures in Jpeg, you don't really have a reason to switch.
  5. ThePup
    ThePup TPF Noob!
    Oct 12, 2007
    108
    Western Australia
    It does? References? I Can't think of any good reason why it should....
    my $.02 worth - I like RAW because I'm a crap photographer, and can fix mistakes better :wink: I Started shooting raw when I took a lovely candid portrait of my daughter under some trees, and because of the trees, there was a green tinge throughout the photo - Would have been much easier to fix, and a much nicer result, had I been shooting RAW!
  6. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    In the digital age, bit depth is everything. Better to have more information than not enough. There is only so much data that Photoshop and other programs can render before it starts making stuff up. Especially when scaling and multiple filters come into play. I have pretty much shot RAW from the get go. It's advantage far outweigh any negatives. IMO.
    Example. I just captured a flying hawk in which it was back-lit and practically a silhouette. Since RAW files capture all the data that the sensor captured (Like a negative) I was able to increase exposure without burinig out the lighter sky and losing contrast. Basically made a shot out of nothing. As a test, I converted the original RAW file into a jpeg and tried the same lightening technique. Everything ended washed out and it took a whole lot of work to achieve a similar result I had with the RAW file.
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
  8. simsi123
    simsi123 TPF Noob!
    Dec 14, 2007
    39
    Margate, Kent, UK
    JPEG groups similar pixes together as the camera process the shot. RAW its basically the digital negative of an image. the same as the cell on normal film. I only use it if I'm creating an album or I need the highest quality, when it comes to P&S JPEG does the job to a high standard, but RAW gives you the chance to change almost any aspect of the image later on when your using PC software
