RAW vs JPG: battery life
Discussion in 'Photography Equipment & Products' started by Val, Jan 20, 2008.
  1. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    I seems that battery life is differnent when shooting in different modes like raw, jpg and raw+jpg. Has anyone done any tests?
  2. shorty6049
    shorty6049 TPF Noob!
    Mar 8, 2007
    1,906
    Minnesota
    i havent done any tests, but i'd assume that just RAW files use less battery than JPEGs because the camera has to compress and sometimes apply noise reduction etc to it, while RAW just throws it straight onto the card
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    how much do you use the LCD? that's got a larger impact on battery than your shooting mode.
  4. solrac8126
    solrac8126 TPF Noob!
    Oct 8, 2007
    120
    Panama
    also the brightness of the lcd
    and auto focus...
    ai servo can consume a lot, let's say on a game.
    maybe the flash?
    i don't know if can be a way for regular people to measure batt life based on raw or jpeg but i don't think it would be noticeable
    allthough i agree with shorty6049, that it could take some more power since the processor is used to do some compression and saturation.
  5. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    Also, a far more intense user of battery life is IS/VR.
  6. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    I think camera applies some sort of processing on RAW anyway. If i shoot RAW on my camera, settings like saturation and ADR are visible on LCD. Although ofc files are the same on computer.
  7. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    The write time is longer for RAW than JPEG. Second to chimping the LCD, writing the file to a flash card uses the most power of any of the cameras functions. (lens functions are another subject.) RAW files use more power to write than JPEG.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yep jstuedle hit the nail without getting a sore thumb. Processing means nothing. The camera is processing for a split second (ok long shutterspeed NR doesn't count), but processing is literally a matter of milliseconds, as opposed to writing which takes half to whole seconds. In either case the microprocessor is running. This is not a computer processor. It will most likely be running full pelt whether it is writing to the LCD the CF card or processing an image.
    What matters is how quickly the overall process finishes.
  9. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Your camera is not seeing the RAW file, it is seeing the embeded jpeg file on the LCD.
    The RAW file has little to no processing on it... hence why it is called RAW.
    There is no measureable difference short of card write time in terms of battery useage between a JPG and RAW file.
    There *are* however, things that can easily shorten battery life far more:
    - Vibration Reduction or Image Stabilizers
    - chimping (a big one right here!)
    - auto preview on the LCD
    - the brightness setting of the LCD
    - the quality/age/condition of the battery installed
    These have a MUCH greater impact on battery life than file format.
  10. Mesoam
    Mesoam TPF Noob!
    Sep 10, 2007
    1,120
    4
    CT
    its just like a laptop computer...run photoshop and other processes on the battery you won't get as good life if you are just typing a note in word...
does shooting raw use more battery
is there more battery consumption while shooting in raw
