real quick PHOTOSHOP question
Discussion in 'Photography Beginners' Forum' started by BuZzZeRkEr, Jul 7, 2009.
  1. BuZzZeRkEr
    BuZzZeRkEr TPF Noob!
    Nov 26, 2007
    436
    Va
    Ok, how do I make the PEN tool act like the lasso tool where I can use it to make an accurate selection? Everytime I use the pen tool it just fills the design with a solid color...or when I select PATHS it doesn't make the lassoed selection. I hope I explained that ok..
  2. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    Around the corner from the Turkey Hill, PA
    In the options bar at the top, there are a few squares which control that, default is set to layer-shapes. Click the paths only box.
  3. BuZzZeRkEr
    Nov 26, 2007
    436
    Va
    I did the paths only box, but it's just a line, it actually won't do the selection
  4. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    Hmmm, obvious question but do you have the free-form pen tool selected (click and hold the pen tool in the toolbox, choose the free-form pen)? I personally like to make my own paths.
  5. BuZzZeRkEr
    Nov 26, 2007
    436
    Va
    No it's not selected, but when I use the freeform pen tool i loose the control point function which is the whole reason I use the pen tool. Even in free form it wont make a selection.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Just draw the path, then convert it to a selection.
  7. BuZzZeRkEr
    Nov 26, 2007
    436
    Va
    This might seem like a dumb question...how do I convert to a selection?
  8. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I can't think of it off the top of my head....
    Try opening the channels pallet. When you create a path, I think it saves that path as a mask. You can use that to create your selection.
    *Scratch that. Open the 'Paths' pallet once you have completed the path with the pen tool. Right click on the path and choose 'make selection'.
  9. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    Once you make a path, command/ctrl click on the path's preview in the paths palette. Tip: double-click on the path in the paths palette and name it, otherwise if you draw another path it will include it in your initial work path
  10. BuZzZeRkEr
    Nov 26, 2007
    436
    Va
    :mrgreen:BINGO!! THANKS EVERYONE!!!:thumbup:
  11. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    Once you finish the fath, you can just right click inside of it, and it will bring up a little right click style menu box that has all your options. Just click 'Make Selection...", and it bring up the selection dialogue box. Easy as pie.
