Reccomend a UV filter for my new (expensive) lens?
Discussion in 'Photography Equipment & Products' started by anubis404, Mar 7, 2009.
  1. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    I'm looking for a quality 77mm UV filter to protect my new Nikon 80-200 F2.8. I'd prefer to spend <$60 on a quality filter. Here the filters I can obtain within my price range:
    Hoya Pro1
    Hoya HD High Definition (how much better is this filter than the Pro1?)
    B+W MRC filter (same price as the HD)
    Kenko Super Pro MC
    Which would provide the highest degree of protection while preserving image quality? Since I am using this lens on a 1.5x body, thinness is not an issue.
  2. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    I like my B&W's the best. However, I only use a "protective" filter near water spray and in heavy dust. Other wise, I take them off.
  3. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    From what I've read, all reviews say that BW or Heliopan cannot be beat by any other brand, however the Hoya HD looks damn good. Which do you recommend?
    A filter is more peace of mind than anything, and even though nothing will probably never happen, I don't want to take any chances. Since the 80-200mm is well coated, I don't think flare will ever be a problem, so I want a good filter that won't cause any flare and will still adequately protect the lens.
  4. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    I have many Hoya's, but they are aluminum instead of brass like the B&W's. I have had problems removing some of my Hoyas, but never a problem with my B&W's. Keep in mind, that I am referring mainly to circular polarizers as I rarely use UVs. However, its the brass rings of the B&W's that make them more attractive to me.
  5. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    Does the BW have all the features of the HD? Which is better?
  6. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    The B&W is multi-coated, and made of quality products. The higher end Hoyas are nice too. I doubt you could go wrong with either. I wouldn't hesitate to get either one. The choice is yours for the making.
  7. blash
    blash TPF Noob!
    Nov 19, 2008
    599
    I've heard that the Hoya HD's are the new king - coated with something that repels fingerprints and stuff. Not sure if B+W can make the same claim.
  8. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    So they are roughly the same? What about the BW being made of schroder (I have no idea how to spell or say this, I just know it starts with an S) on the BW? Sorry for the vaugness, I can't remember the name of the glass the BW is made of.
  9. flea77
    flea77 No longer a newbie, moving up!
    Feb 6, 2009
    593
    34
    Huntsville, TX
    Try this UV, Haze & Skylight filters (2) and especially the part here:
    Hope this helps!
    Allan
  10. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    I just picked up two 77mm Super HMC Hoya filters for $36 each. You can spend more money, but I don't know that your getting much extra value beyond this point.
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Given that under normal circumstances (not shooting directly into an active light source) you can't tell a Hoya SHMC apart from a no filter, even on high end glass, all of those filters would be a good but probably expensive choice.
    All filters flare when shooting into the light so spending too much money again is a waste, and as far as I am concerned the Hoya SHMC filters flare nicer than their Pro1D filters too.
    http://www.thephotoforum.com/forum/...100830-more-hoya-filter-comparison-tests.html
  12. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    After many reviews, I went with SHMC filters also, due in no small part to Garbz and Sabbaths Reviews. I can only say good things about them. For the price I think they are the best quality and value combo.
80-200 mm uv filters
best 77 mm protective filter for nikon 80 200 f2.8
best filter for nikon 80-200 lens
best uv filter for nikon 80-200
how much should you spend on a video lens filter
how much to spend on a lens filter
how much to spend on uv filter
uv filter how much to spend
uv filter lens nikkor 80- 200 2.8
what is best protecive filter for nikon 80-200 mm f2.8
