Rechargeable batteries for flash get really really hot
Discussion in 'Photography Equipment & Products' started by DeepSpring, Jun 15, 2007.
  1. DeepSpring
    DeepSpring TPF Noob!
    Jul 12, 2006
    1,451
    Los Angeles
    I have the energizer rechargeable 2500mah batteries and the little charger that slides into itself for storage. When I charge the batteries in it they get really really hot and I just wanted to check if this was normal. Is it ok to put them in my flash so hot or maybe stick em in the fridge for a few minutes first?
  2. Mike_E
    Jan 26, 2007
    5,327
    266
    In something like this I don't know if I'd trust just anybody to keep my flash from melting/bursting into flame. Have you been to the battery maker's web site and looked through their FAQs?
    mike
  3. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    Cold will kill part of your charge in that type of battery. If you are concerned, just let them cool down... also, if you are using the charger provided by the manufacturer and matching batteries, you will be OK. Don't know why it would be THAT time sensitive that you couldn't wait a couple minutes between taking them out of the charger (yes, it is normal for them to get warm) to putting them in the flash.
  4. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    I expect mine to get hot but it scares holy hell out of the wife when she touches them while plugged in.
  5. DRodgers
    DRodgers TPF Noob!
    Apr 11, 2007
    290
    Stoney Creek Ontario
    I've tossed 15min chargeable energizers into my sb800 hot numerous times and have had no problems.
    I would however recommend that you let them cool naturally first though just to be safe.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    That's the problem with small chargers...I think I have the same one...they don't dissipate the heat very well. Excessive heat is what may eventually shorten the life of your batteries.
    This is why it's better to have a bigger charger...some of them even have cooling fans I think. Personally, I charge mine in my office where already have a fan. I just put the charger in front of the fan and it keeps the batteries cool.
    Actually, I'm thinking of getting a better charger anyway. I don't like that my small charger doesn't tell me how much of a charge they have. It just has a light to say they are charging. My camera batter charger at least flashes to tell me how much is left to charge.
  7. newrmdmike
    newrmdmike TPF Noob!
    May 8, 2006
    2,107
    it varies.
    i had a duracell explode (kind of, not quite as dramatic as it sounds) in my sb-800
    ii could hear stuff bubbling out of it, and opened the compartment up, the batteries were rediculously hot, and one had acid coming out of the end, like boiling out.
    i don't use rechargables . . . but i like the energizer e^2 aa's, they are just really expensive.
  8. NJMAN
    NJMAN TPF Noob!
    Aug 1, 2006
    2,104
    Far beyond the bowels of human existence...Minneso
    I have this exact same one as well, and just noticed yesterday again after charging them that they got very hot. I let them sit at room temperature for 15-30 minutes before I put them back into my 580EX speedlite, that is, if I have enough time to do so and not rushing off somewhere to use my equipment. But sometimes I dont have a choice. It doesnt seem to affect the proper functionality of the speedlite.
  9. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    batteries getting hot is an indication of over-charge.....some charger are stupid and they keep charging your batteries even though they are full.....the excess electrons have no room to fit but turn into heat and dissipated.
  10. shorty6049
    shorty6049 TPF Noob!
    Mar 8, 2007
    1,906
    Minnesota
    i have that happen all the time with my energizers. i have a 15 minute quick charger and they get hot when i use that, havnet used a regular charger in a while though...
  11. DeepSpring
    Jul 12, 2006
    1,451
    Los Angeles
    Thanks for the info. Usually there is ample time to let em sit first but there are those times when you just have to run off to a shoot.
  12. flyingseale
    flyingseale TPF Noob!
    Jan 21, 2007
    271
    NiMH cells charge with an exothermic chemical reaction, so they will get WARM when charging. Also, most chargers simply charge for a set time which means the cells are not only warm from the proper charge but they get HOT due to overcharging. If they get too hot the pressure builds up and they 'vent' which you'll notice as a hissing noise. Bubbling is fine...hissing = vented. In extreme cases, you'll not only get gases escaping from the vent, but the electrolyte too. This is potassium hydroxide in NiMH, which is a very strong alkali...so wash your hands properly and be careful not to get it in your eyes.
    Whilst this might sound scary there is no need to worry about using them hot. In fact they perform a lot better when they are warm.
    If you are concerned about how hot they get the only solution is to get a decent charger that monitors the charge of each cell individually and terminates it when complete. Here's a couple of examples from Maplin in the UK.
    http://www.maplin.co.uk/Module.aspx?ModuleNo=217900&criteria=battery charger&doy=24m6
    http://www.maplin.co.uk/Module.aspx?ModuleNo=105064&criteria=battery charger&doy=24m6
    BTW, if your charger is several years old it might only be designed for NiCd cells. Charging NiMH on a NiCd charger will also make them hotter than expected due to the different charge algorithm.
    Mike
hot rechargeable batteries
is it normal for rechargeable batteries to get hot
my rechargeable batteries are hot
rechargeable aa battery getting hot
rechargeable batteries energizer getting really hor
rechargeable batteries get hot
rechargeable battery hot
what does it mean when rechargeable batteries get hot
why do my rechargeable batteries get hot when i use them
why do rechargable batteries get hot
