Rechargeables in flash?
Discussion in 'Beyond the Basics' started by Chris H., Mar 16, 2008.
  1. Chris H.
    Chris H. TPF Noob!
    Jan 10, 2008
    12
    Harrisburg, PA
    Hi,
    Ive heard mixed talk about using rechargable AA's in a flash....I just wanted to hear everyones opinion on whether its a good idea or nt and if you are using them what type?
    Thanks!
    Chris
  2. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    Rechargables are all I use - 2700mAh NiMh
  3. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    Same here I only use them.
  4. FrimpyEIBW
    FrimpyEIBW TPF Noob!
    Dec 2, 2007
    66
    Hilton Head Island, SC
    I use them too. Just make sure you keep each set seperate. I have 2 flashes, and 4 sets of 4 rechargeables. 2 sets of Duracells (but they are different colors) a set of Energizers, and a set of Quantaray batteries. That way, you keep each set together. That is important, especially if you have some sets that are older than others.
    I get about 200-250 flashes before I have to change the batteries.
  5. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
    Same! :)
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    No I'd rather go through 4AAs every day just for the sole purpose of pissing off Capt. Planet and his army of greenies.
    :roll:
    For the record forget NiCads. NiMh are the only really affordable acceptable solution as NiCads don't produce enough juice quickly enough and the voltage drops quickly when they start going flat so you get less photos out of a charge.
  7. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Rechargeables here too. I use 3 different kinds in my SB-800 and find that the 2700's give you about 10-12 more flashes than the el-cheapo rechargeable ones. In a pinch it is always worth it, but its rare that I am in circumstances where 2 sets of recharged batteries are used in an evening event. I always use the 5th external battery holder for my SB-800 to shorten latency between shots. Makes purchasing them an interesting situation. :)
  8. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    Rechargeable here.
  9. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    Rechargeables here as well.
    Alkaline batteries are OK when they are fresh, but the recycle times start to get longer and longer, even when the batteries still have juice. NiMH batteries tend to keep the recycle times faster, until they are almost dead.
    Of course, there is the environmental aspect. Batteries are very bad for landfills.
  10. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    Ditto ... everybody above
    (except GARBZ, of course!)
  11. derekclapham
    derekclapham TPF Noob!
    Mar 5, 2008
    19
    Sydney, Australia
    I use rechargables as well. However, I keep a pack of 12 non-rechargables in my camera bag at all times just in case the re-chargables let me down for some reason (It's never happened).
    I would suggest you get yourself a quick charger. I've got an Energiser charger that charges 4 AA batteries in about 40 minutes. It also uses my 12v outlet in the car so if worst comes to the worst I can charge up another 4 batteries in the car.
    From memory I've got 16 rechargable AAs, but I really need another 4 because the SB-800 takes 5 (with the side battery). As Jerry said, it makes buying batteries an interesting experience.
  12. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    All I use anymore. I have Energizers and, Duracells both work great. I just carry about a dozen extra. You can never have enough juice.
