Red Carpet Event Photography
Discussion in 'Beyond the Basics' started by photodeb, Dec 8, 2006.
  1. photodeb
    photodeb TPF Noob!
    Dec 8, 2006
    4
    I need your advice if you are able. Tomorrow night I am about to shoot my first red carpet event. I have never done this before and all I own really is a Canon XTI, the lens it came with and an additional Canon EF 135 mm lens. Obviously I believe I may have some shopping to do before the event.
    what is the least I can get away with-equipment wise.. since money is tight and quite honestly since Ive never done this before Im quite nervous....
    The party planner emailed me to let me know what he wanted and mentioned if I could get a strobe so it looks more professional..this is for a company event where it is a red carpet theme. I've never used a strobe and quite frankly dont even know much about them.
    I've been shooting for only 3 months and my only focus has been portraits in natural light. Please help if you can- its tomorrow night...
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Welcome to the forum.
    If it's an night...you will need a strobe. I suggest the Canon 430EX. It's not particularly cheap...but it's a darn good flash. If you can find the older version, the 420EX...it might be cheaper.
    Don't get a Canon 'EZ' flash...they don't work well with new cameras like yours.
    The advantage of getting a Canon flash...is that it will work with the camera and use all the fancy technology. It should really help...if you don't know what you are doing.
    You really don't want to use the built-in flash. It's not very powerfull...and the chance of red eye is pretty high.
  3. photodeb
    photodeb TPF Noob!
    Dec 8, 2006
    4
    Thanks for the advice! I'm assuming the lens that came with the camera should be ok...?
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It's certainly not the greatest lens, or even a pretty good one...but it's not terrible. (well the build quality is terrible...but the glass is OK).
    I have that lens...and to get the best quality out of it...I avoid shooing at it's widest (18mm)...and I avoid shooing with the aperture wide open (F3.5-F5.6)...I like to keep it at F8 if I can.
    If you want a great lens, at a great price...pick up a 50mm F1.8.
    If you have some money to spend on a lens...then I would consider a zoom with a maximum aperture of F2.8. The Canon ones are expensive...but Sigma & Tamron offer great F2.8 zoom lenses for much less.
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    is the 135 a prime? if so, than that should work fine if you can get close enough .
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    135mm on an XTi...is quite the telephoto. They would have to be standing pretty far away to get more than a person's head in the shot.
  7. ladyphotog
    ladyphotog TPF Noob!
    Oct 4, 2006
    215
    Georgia
    And if you use the 135 you will need more power from your flash so make sure you have one that will cover the distance. Light falls off over distance so practice with it if you can.
  8. photodeb
    photodeb TPF Noob!
    Dec 8, 2006
    4
    yeah the 135 I think would have me having to stand too far away..hmmm..do if I invest in another lens, any other suggestions besides the one suggested...?
    BTW I decided I may have to rent everything..this is getting costly!
  9. DeepSpring
    DeepSpring TPF Noob!
    Jul 12, 2006
    1,451
    Los Angeles
    Like Mike said the 50mm 1.8 is great and its under $100
    I did my schools homecoming dance with that which I imagine wouldnt be ALLLLL too different then a red carpet event in the lighting and distance.
    http://www.bhphotovideo.com/bnh/con...s&Q=&sku=350973&is=REG&addedTroughType=search
    There is an example of one of the sigmas he was talking about.
    this one is $100 less but B&H dosn't have it yet so I don't know if you could find it somewhere else
    http://www.bhphotovideo.com/bnh/con...s&Q=&sku=352403&is=REG&addedTroughType=search
  10. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    All good and accurate pointers above...
    one thing to note... All EOS digital SLRs require E-TTL compatibility. There are a few aftermarket flashes that advertise EOS E-TTL compatibility but there have been many reports of major incompatibiities. Stick with the Canon "EX" line of flashes; 430EX (replaced the 420EX ) or 580EX (replaced the 550EX). The Canon EZ line is basically incompatible with your camera. Unfortunately, Canon's flashes are not cheap. I would recommend getting a slightly used 550EX over a brand new 430EX if you can find one. A bit more power.
    The 50mm f1.8 is probably the biggest bang for the buck lens in Canon's lineup.
    oh yeh..
    just make sure you practice with the new equipment a few times prior to the event. Nothing is more fustrating than learning the unfamiliar equipment on the fly. Also, don't forget to buy good quality batteries for your flash and carry extras...
  11. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    One of the biggest problems you are going to find is speed of focusing. If you have the opportunity to rent things you should also consider a body that will focus fast enough so you do not have to keep people waiting while you focus.
  12. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    think 'diffuser'.
    Direct flash is often is much too contrasty.
    If the room has a standard height, white ceiling try shots with the flash bouncing off the ceiling.
    Practice in advance
    Practice in advance
    Practice in advance
    Practice in advance
is 50mm a good lens for red carpet photoshoot
